Old 06-24-2004, 12:28 PM
d_man_83 d_man_83 is offline
Send a message via Yahoo to d_man_83
Cool 1G engine in 2G body
I recently sucked up water from the cold air and of course got the gine blocked. I was wondering, would it be better to fix the engine or to put it a 1g engine in it. Since it has bigger heads and all. I want more power of course. The car has a 420A DOHC engine in it. What do you suggest? Is it possible to change the 2g engine for a 1g one? What mods need to be done? And what type of engine should be replaced with?
Old 06-24-2004, 12:44 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: 1G engine in 2G body
Well, I'm assuming you would want to drop the 1g 4g63 engine in, right? I know you don't want the silly 1.8 liter 1g engine Anyways, it is very possible to do that swap, but it would take LOTS of $$$! For one, the engine is completely backwards of the 420A and you'd have to do lots of work on the actual engine bay itself to get it to fit right. IMO, I wouldn't do it unless I had lots of money to blow on whatever I wanted. If I were you, I would just buy a new 420A engine and build it up (block/head work, cams, etc). That should keep you busy for quite a while
Old 06-24-2004, 12:59 PM
From what the mechanic told me, the problem would more than likely be in the block. Wouldn't it be cheaper to get the block fixed and at the same time have the heads ported or something? I know that chaning the heads and intake manifold to the 1g takes alot of work. Yeah I was thinking of getting this one fixed and work on it.
Old 06-24-2004, 02:23 PM
That'd definitely be the way to go if you decide to stick with the 420A: Build the motor and then add some boost!
Old 06-24-2004, 02:48 PM
anybody know where i can get the block for this car?
Old 06-24-2004, 04:52 PM
Partizan's Avatar
Partizan Partizan is offline
Just check a junkyard for a wrecked one and scavange the block from the motor.
Old 06-24-2004, 07:35 PM
is there any other motor i can fit in that sits on the same side?
Old 06-24-2004, 07:38 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Nope, you cannot swap motors like a Honda can. 420A is what you are stuck with. My advice is switching cars instead of a turbo kit. Test drive a GSX.
Old 06-24-2004, 07:40 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
The 2.4L from a Stratus but it would be backwards. Search for it on 2gnt.. if you want to know what you need to do for it to fit.
For Sale 98 Eclipse GS, 5 spd
Old 06-24-2004, 09:34 PM
thanks alot for all the feedback
really appreciated
Old 07-12-2004, 06:57 PM
420Apower 420Apower is offline
here is a site I happened to find. I have a blown block and have to start all over also. It is a rebuild kit for the 420A.
http://www.importperformanceparts.net/
