Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 06-24-2004, 08:06 AM
John1103 John1103 is offline
Question Idle:Revisited
It does seem to run a little rough as of late. And It idles at this speed whether I'm in gear or not. When I do put a little gas to it to raise the RPM to around 6 or 700 it smooths out quite a bit. But I did call a tech at my local dealer the other day and he said that my idle is probably normal. Should I get a second opinion?
Old 06-28-2004, 10:41 AM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Re: Idle:Revisited
It could be something as simple as you got cheap gas. Next time you fill up try putting a grade higher than you already do and see if that helps. I had had that problem to and just started putting plus gas in and that seemed to work. If not I would get a second opinion.
White 07 STI, Bone stock for now
