Old 06-24-2004, 07:48 AM
33Chev 33Chev is offline
ABS continuous buzzing noise 99 Silverado
Trying to help my brother (telephonically) with his 2wd 1999 Siverado 1500 (4.3 auto)pickup. He says that when he starts it, the ABS lights comes on and he can hear the ABS system (probably pump) just buzzing away. The noise (pump) won't stop. Any typical cause (GM campaigns) for this condition?
The vehicle also has a problem with engine just cutting out while being driven...if you then place it in neutral while rolling it starts back up. He tested all of the sensors (rec'd misfire codes of course)...we are about to install a used ECM...does anyone know if the (engine) ECM has any control over the ABS system or does the ABS use an independent ECM.
He picked the truck up cheap...and now realizes why...might be a flood victim truck?
thanks folks....I'm new to this page but really like it.
Ed
Old 06-24-2004, 10:56 AM
rsatter22 rsatter22 is offline
33Chev,
There is a common problem with the ABS on these. A switch goes bad in the ABS control and will not shut off the pump. If you search back in the forum, you can find lots of info on this.
RDS
Old 06-24-2004, 11:12 AM
thoot12 thoot12 is offline
Remove the fuse to the pump from under the hood to stop pump before it burns up...it's a 60amp I think.
Trey
Old 06-25-2004, 05:52 AM
Thanks guys
I found the post...really appreciate the help.
Old 06-25-2004, 04:53 PM
jbjim jbjim is offline
continuously running abs pump
I'm experiencing a similar problem and have done enough research to find the tsb on the ebcm...however I am still experiencing the problem after replacing the ebcm, in fact my pump runs with the key on or OFF! Anyone else experience this problem, and if so did You find the solution?
Please let me know if you have been successful! [email protected]
Thank You!
Jim...
Old 06-26-2004, 02:19 PM
allmarsh allmarsh is offline
ABS module repair
I also had my ABS module go out on my '99 Silverado. It has around 60,000 miles. The ABS light was on and the pump was buzzing/running constantly. I removed it and sent it to Circuit Solutions for repair. After getting it back in quick time I reinstalled the module and haven't had any further problems. This repair cost me about $100 as compared to many times that to have it fixed by GM. You can find them on the web and on EBay. From what postings we found on the internet, this ABS failure seems to be a chronic problem.
Old 06-26-2004, 04:20 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: ABS module repair
I recommend Circuit Solutions for the repair of your ABS modules on those body style trucks.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 06-26-2004, 09:10 PM
Re: Re: ABS module repair
I have already replaced the EBCM! and have still been experiencing the problem! Any ideas as to why?....Remember, pump runs even without the key in the truck...!!!
jim...
Re: ABS continuous buzzing noise 99 Silverado
thanks but......
Old 06-27-2004, 08:27 AM
GMMerlin's Avatar
I know stuff
Re: Re: Re: ABS module repair
jim...
Did you replace the EBCM with a new one or a used one?
GM WCT
PM Me for details
Old 06-28-2004, 05:59 PM
Puffnstuff's Avatar
Puffnstuff Puffnstuff is offline
Send a message via ICQ to Puffnstuff
You have to remove the 60a fuse to stop the pump from running all the time. The abs unit on my 99 silverado went at 30k but I didn't like it anyway so I just pulled the fuse and taped the idiot light so I couldn't see it and left it at that.
06 Toyota Tundra Double Cab
