Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-23-2004, 11:14 PM
Lude_03 Lude_03 is offline
cooling fan
is there any way i can have a over ride switch for my cooling fan so at the track i can cool the engine faster. my friend did it to cavalier...
Old 06-24-2004, 12:05 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: cooling fan
I don't know of one that you can manually change it between track and daily driving but Mugen makes a fan switch that turns on the fan sooner all the time if that helps. I'm assuming by your name you have a prelude and possibly a h-series so: http://www.jhpusa.com/catalog/produc...roducts_id=217
Old 06-24-2004, 02:02 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
yes its very easy. just hook up a switch from a power source on your car, i hook it up directly from the battery with one of those little fuse wires you can add, and i hooked it up to a switch, then i did alittle splice in the wire after the fan relay and hooked up my switch wire. so that way it will turn on with the relay or with the switch.
i hooked up my fan because my relay blew.
Team Lonely Drivers
Old 06-24-2004, 05:15 PM
Re: cooling fan
what color is the wire that u did it on
