Old 06-23-2004, 10:04 PM
ol' dude's Avatar
ol' dude ol' dude is offline
Stripping Lacquer
How in the world do you strip lacquer based paint without damaging the plastic??
BUILD TO SATISFY YOURSELF AND NO ONE ELSE!
Click to view ACME's website
Old 06-23-2004, 10:13 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Stripping Lacquer
Brake Fluid.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-23-2004, 10:26 PM
RallyRaider's Avatar
Zomby Woof
I use oven cleaner, the more caustic the better (make sure you use gloves and avoid the fumes). If you're in the States Castrol Super Clean is often recommended.
Old 06-23-2004, 10:27 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
MEK...Oh wait, you dont want to damage the plastic. I thought you wanted to melt/vaporize it.
Try CSC.
-Mike
Old 06-23-2004, 10:31 PM
Zomby Woof
Re: Re: Stripping Lacquer
Should that quote have a smilie or two in there somwhere?
Old 06-23-2004, 10:34 PM
mike@af's Avatar
Re: Re: Re: Stripping Lacquer
Yea, but I just got home from work and didnt go to the advanced editor. I know half the smilie codes, I dont know why I didnt use one...whatever. Im exhausted.
-Mike
Old 06-23-2004, 10:41 PM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
ive always wondered if brake fluid would damage the plastic
Old 06-23-2004, 10:49 PM
ZoomZoomMX-5's Avatar
If you use brake fluid, don't immerse it. Just wipe it on and put the model in a bag. Some plastics don't like it, some aren't fazed by it.
PollyS Easy Lift Off is good for removing lacquer, seems to be harmless to plastic. Oven cleaner and CSC take a lot longer, depending on the color/age/etc.
Matt (CADGUY) found out that 91% rubbing alcohol removes HOK lacquer. Apparently it works on Tamiya as well. Might be worth a shot as well.
My Fotki Album
Old 06-23-2004, 11:50 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
The one time I used it on a model it got the plastic a bit soft. But a little sanding fixed that
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 06-24-2004, 12:19 AM
pre98zetec's Avatar
I have a civic that's been sittin in brake fluid a month and it hasn't hurt it a bit.
-Josh-
Old 06-24-2004, 12:25 AM
bigford550's Avatar
bigford550 bigford550 is offline
PollyS Easy Lift Off works good on some
types of paint but it makes a mess
Old 06-24-2004, 07:29 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
I've used 91% isopropyl and had very good results with it. Took Tamiya laquer and primer off, down to the plastic. If you do use brake fluid, do so at your own risk- some plastics it will attack, some it won't.
Besides, isopropyl is soooo cheap, and you don't have to worry about dumping it afterwards.
PHOTOBUCKET SUCKS
Old 06-24-2004, 09:36 AM
Turbo Monster's Avatar
Turbo Monster Turbo Monster is offline
will Isopropyl take off spray paint? what about sprayed on clearcoats?
Well I try my best To be just like I am
But everybody wants you To be just like them!
~Rage Against The Machine
Old 06-24-2004, 09:58 AM
MPWR's Avatar
Yeah, the strong stuff (91%) will. It'll take off Tamiya clear leaquer, and any acrylic. It will of course more than likely work on whatever's under the clearcoat, also. Haven't ever tried it on enamels, don't use 'em much anymore- but CSC works great on them. What are you stripping?
PHOTOBUCKET SUCKS
Old 06-24-2004, 10:10 AM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
I''m busy to remove paint frpm my Skyline. At my LHS they recommended oven cleaner. It's called Blue Wonder. They said it works great. Will let you guys know if it turns out nicely.
