Old 06-23-2004, 09:05 PM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
Rocker Arm Came Off
i took the valve cover off and found a rocker arm inside the head... hahaha i couldnt stop laughing... inside i was crying but ya here comes work... putting a new head and water pump... then back on the road... WISH ME LUCK!!!
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
Old 06-23-2004, 09:19 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Rocker Arm Came Off
Thats twice I've seen this in 2-3 months... I've got a collapsed lifter or two, I need to get new ones!
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-23-2004, 09:56 PM
RSLaser RSLaser is offline
GOOD LUCK...couldnt you tell it was like that before you pulled off the head...or atleast hear it?
1991 Plymouth Laser RS
Only sat for a few years....
Old 06-23-2004, 10:02 PM
AF - Advisor
If the rocker falls off, the valve just stays closed. There wont be any noise. Unless its like the other situation I mentioed above. It fell off and got into a tight spot, and the cam kicked it out the side of the head Still hard to notice at first though, had to look at the pics a few times to see it.
Kevin Jewer
Old 06-23-2004, 11:23 PM
98GSX's Avatar
hah its funny when you blow a freeze plug and it busts the cam gear cover...hehehe
^^^ hehehe
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
