Blazer won't start
Help!!! My 97 Blazer won't start. I changes out the ignition switch, after reading many of you had problems with it. Before the change out, I had no dash lights, no fuel pump and no fire to the cylinders. The new switch cured all the problems noted above, however the thing still won't start. I'm stumped, smells like I have gas, but not sure if the injectors are actually woking. I actually poured a small amont of gas down the throttle bldy, and still no fire. Please help.
BLAZER won't start
Replace your coil wire,during replacement of my 97 ignition switch, the wire had a white spot on it where it burnt through.
97 blazer wont start
I have a 97 blazer 4.3 v6. it died on me in the garage. The fuel pump is not coming on. It will spin over fine, but not start up. I also noticed the turn signals stopped working and I can not get it out of park. I turned the switch all the way over, pressed the brake and it still wouldn't come out of park. I kept tinkering with it and the fuel pump came on and the signals started working and then I cut it off and now it is dead again.
I was told a faulty computer will cause this. Does anyone have the same problem? Thanks, JJ |
Blazer will not start
I have a 99 Blazer that will not start. Everything comes on except the lights. Was told it was the connection to the fuse relay, but must not be because it will not start today. Do not know what to do. I have this blazer two different places. Tonight it may roll over and start. Tired want it fixed, but do not know what the problem is.
Thanks, bruckman |
Re: 97 blazer wont start
I was wondering if you found out what the problem was mine done the same exact thing. Please let me know something |
