Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 06-23-2004, 06:15 PM
pckx pckx is offline
Starting problems
I have a 96 gmc sonoma and im having trouble starting it, i put the key in and wait for the fuel pump to come on and then shut off and i try it and it dosn't start, then i do the same thing a second time and it usally start's at the most it takes 3 time. i was wondering if it had to do w/ somehting on the steering column or something. Also the engine was just put in after a rebuild. I checked all the wiring and everything is hooked up right any suggestions???
Old 06-25-2004, 05:36 AM
GMCTech GMCTech is offline
First, replace the fuel filter if it hasn't been done fairly recently.
Next get some fuel pressure readings. 1st key on, 2nd key on , etc.
I think you'll find (if it's not a clogged filter), that you've got a tired fuel pump, and will need replacing.
By the way, after each key on cycle, let it sit for a minute or so and watch the pressure, it should hold and not drop.
Hope this helps.
Old 07-05-2004, 10:57 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: Starting problems
You may have to replace your fuel pump relay.
