Help with '99 Front Rotors 4WD
I have my rotors off of the vehicle and want to replace them and the bearings. But there is a hub attached (that has the bearings inside) and I cannot get this off of the old rotors. The new rotors I have do not have this hub attachment so I assume that I need to take this off of the old rotors and attach it to the new rotors. Is this what I am supposed to do? If so, how? If not, did I receive the wrong rotors. Any help would be greatly appreciated. Thanks!
Re: Help with '99 Front Rotors 4WD
Put The Old Rotor Back On The Truck Spray The Remove The Bolts That Hold The Hub To The Rotor
Pry Bar To Seperate It Or Air Hammer |
Thanks 2eyefishclaw. I will try what you have suggested.....though I will not have a chance again until Saturday morning. I'll post back afterwards. Thanks!
I was able to seperate the hub from the rotors after spraying on some liquid wrench. I put new parts on and now I am getting a loud rubbing sound (which is constant). Is this normal for new brake pads and rotors. I put on non-asbestos front pads instead of ceramics (but I thought this might lead to squealing not rubbing sounds). Do I have something tightened too much? My previous pads were 90% worn and the rotors were warped. Thanks for any help as this is the first time I've ever replaced brakes and rotors.
