Go Back   Automotive Forums Car Chat > Ford > Contour
Old 06-23-2004, 12:50 PM
xp-slayer xp-slayer is offline
why won't my ar cd player play any sound?
well i connected all the wires from my car's original wires to the wires coming out of the radio. And yes they are all right. I know how to connect the wires and i double checked that all the wires are correctly connected. No when I turn on the car only the radio turns on and starts spinning the cd. But no sound comes out of the speakers and just really quiet bass comes out of the woofer. So then i ripped everything apart again and tried to connect the radio directly to the battery. I connected the yellow and red wires to the positive and the black wire to the ground. Then I connected 2 speakers one from the purple set of wires and the other from the white set of wires and still there is no sound. I tried different speakers also and same problem. I know both sets of speakers do work since I tried them on a friends car. Any suggestions would be greatly appreciated.
Old 06-24-2004, 01:34 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
I installed an aftermarket cd player in my friends early 90s cougar and it had the same problem. Turns out, circuit city sold us the wrong wiring harness.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 07-11-2004, 09:23 PM
hallboy hallboy is offline
Re: why won't my ar cd player play any sound?
If this is still a problem, you may need an in car amp bypass harness. Ford amps will not allow sound to pass from an aftermarket head unit. You can get on from best buy. They can also verify if your car needs it. Different models have different set ups. Good Luck,
Hallboy
Old 07-13-2004, 12:55 AM
Re: Re: why won't my ar cd player play any sound?
Hallboy
My aftermarket alpine headunit worked just fine without a factory amp bypass.
"The CEG Nazi"
www.contour.org
Old 07-14-2004, 10:18 PM
have you verified that the head unit works? Maybe just put an extra speaker out of the car to one of the leads and see what happens. With newer cars it can be a real pain with out a harness to ensure all the connections are right. Best of luck on this.
Old 08-16-2004, 05:57 PM
canr2001 canr2001 is offline
Send a message via Yahoo to canr2001
i had a pioneer that played just fine and sound passed through the amp but after about 6 months it quit and i replaced the radio still no soud bypassed the amp got jittery sound for awhile the worked fine the amps behind the glove box
Old 01-24-2005, 02:48 AM
bob_axum78 bob_axum78 is offline
Send a message via AIM to bob_axum78 Send a message via Yahoo to bob_axum78
Well you need to also make sure that the remote wire is hooked up that is very important without that it will not work
