Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-23-2004, 11:41 AM
CBCamry96 CBCamry96 is offline
Question 96 Camry Brake Warning Light
Have never had any problems with this, or any of my past Camry's.
Recently the brake warning light has appeared. It does not stay on, just comes on periodically and then goes off. I have noticed this only occuring in the morning, and usually during or right after a left turn.
If there is a problem with the brakes, wouldn't the light stay on at all times? I'm guessing there is just a faulty wire of some sort in the dash, but would certainly appreciate any info / suggestions anyone may have.
Thanks!!
Old 06-23-2004, 12:30 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 96 Camry Brake Warning Light
Probably just your brake fluid level sensor is being activated by the shifting brake fluid in the Master Cylinder during the turns. Add some brake fluid to the reservoir.
Old 06-24-2004, 08:43 AM
Thumbs up
Thank you kindly
Old 06-24-2004, 09:47 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
low brake fluid - brake light:
unless you have a leak, low fluid probably results from worm brake pads, (backing moving out in the calipers) so check for brake pad wear also. For the front, you remove the wheel and look through an inspection slot in the front of the caliper to see brake pad thickness remaining.
