Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-23-2004, 11:27 AM
MMSF MMSF is offline
Help! drain plug
thinking about flush the coolant system b/c the coolant looks brown again.
Last time I did't drain the coolant in the engine, could someone tell me the exact location of the engine block drain plug on a 97 4-cyl. under the hood or underneath the car? which side? Many thanks ahead of time.
Old 06-23-2004, 01:23 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: Help! drain plug
It's on the side of the engine, right by the oil filter. Also be sure to get the drain plug on the radiator, accessible by removing the splash guard by the corner of the front bumper cover on the driver's side.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 06-23-2004, 10:19 PM
Unhappy Re: Re: Help! drain plug
Kind of strange: no coolant flowed out of the engine block drain plug. What is going on?
Old 06-23-2004, 10:28 PM
Did you drain the radiator first before removing the engine drain plug?
Old 06-23-2004, 11:40 PM
Yes, I drained the radiator at first, then removed the engine drain plug.
Old 06-24-2004, 09:45 PM
Well in this case, more than likely, all of the residual fluid in the block was drained through the radiator. There is no need to worry, nothing's wrong with your car.
