Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 06-23-2004, 10:57 AM
kyrx7 kyrx7 is offline
oil pressure
my oil pressure gauge when i first start the car is normal it moves around alot at first but after awhile it goes to 0 and stays on 0 or a little above. it uses no oil between oil changes. and leaks no oil. it runs great except for the boost problem that noone seems to be able to help me with. this is a 1993 twin turbo it has 113000 but i have papers from previous owner where the turbos and engine was rebuilt at 60000 but anyone can make papers. didnt care cause i got the car at a good price.
Old 06-23-2004, 01:44 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: oil pressure
you have a problem if your rotary doesnt burn oil..
Old 06-23-2004, 02:17 PM
Re: oil pressure
its never low and clean as a whistle but i also change it every 2000 miles.
Old 06-23-2004, 02:19 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: oil pressure
yea that is deffinately strange... can't think of anything that could cause it right now...
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 06-23-2004, 02:56 PM
Re: oil pressure
could it just be a bad gauge
Old 06-23-2004, 08:13 PM
tomminajar's Avatar
tomminajar tomminajar is offline
Re: oil pressure
Sending unit - No ?? Ground it out and see if it works.
Old 06-23-2004, 10:55 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: oil pressure
http://www.mazdatrix.com/FAQ/ORING.HTM
1988 10th AE Edition TII
More mods then you have.
Old 06-24-2004, 12:15 AM
dayna240sx's Avatar
dayna240sx dayna240sx is offline
Banned
Send a message via AIM to dayna240sx
Re: oil pressure
I'd check the sending unit, then the gauge. I doubt its the front o-ring, if it were, the engine wouldnt have lasted as long as it has.
Old 06-24-2004, 02:34 PM
tomminajar's Avatar
Re: oil pressure
Hook up a mechanical gauge briefly to make sure
