Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-23-2004, 10:15 AM
xzciviczx xzciviczx is offline
Aftermarket Intake Manifold, PCV Question...(turbo application)
Hi,
I have searched these forums and searched the net, and can not find this information...but I need this info ASAP! Thanxz!
I am running a 95' Civic DX d15b7 w/full turbo setup...je/srp pistons (standard bore), crower rods, bigger cam, 310cc RC injectors, obx intake manifold, etc...
(turbo not yet installed, just rebuilt engine want to work out bugs before installing turbo)...
I have an aftermarket intake (OBX) inwhich required ALOT of "CUSTOM FABRICATION"
Problem is the Aftermarket Intake has all the correct nipples...only thing it is lacking is a spot for the PCV Valve...(it was originally mounted/bolted on the STOCK INTAKE MANIFOLD)
The car runs fine, however CEL is on without it...and it lopes pretty bad hehe...due to some vaccume...inwhich is due to the PCV problem im asking about...
I do not have any time nor do I want to or plan on taking this intake to a machine shop to get this PCV deal machined on...(yes i know, i have a deadline to meet...which is not good when your building a engine) :crook:
I was wondering if there is a possible way to bypass this problem or hook it up differently or something of some sort...im sure others out there have had this same problem with aftermarket intakes!!!! THEY A BYTCH!!! I have searched and only found things that concerned a "CATCH CAN" setup...however people argue too much of their own opinions and im confused...some say ditch the whole pcv some say you have to have it...someone please!!!! GEEZE!!!
(what ever happened to "SIMPLE BOLT ON"? Guess we have to work for it now days?) Owells, please HELP ASAP!!!!
I appreciate it!
Old 06-29-2004, 01:34 AM
RPMtuner RPMtuner is offline
Re: Aftermarket Intake Manifold, PCV Question...(turbo application)
your crank needs to breath it would be wise you get it machened
