Old 06-23-2004, 09:36 AM
rruddfan21 rruddfan21 is offline
(yet another) problem
starting yesterday afternoon after driving for awhile, pulling down my alley, the car got real shaky and has a hard time accelerating. this morning i noticed that the tailpipe is shaking good and makes a puttputtputt noise that is noticeable in the car with windows up. since i've owned it, this car has had a bad exhaust smell of some sort, so is it an exhaust problem? i had a new tail pipe and resonator put in in december
Old 06-23-2004, 10:37 AM
pind pind is offline
Re: (yet another) problem
Not 100% sure here, may be barking up the wrong waterfall, but that bit about the bad exhaust smell tells me that most likely your cat is going bad. ( Hence, smells like dead cat ) anyway, might want to get that checked out before you dive feet first into something more complicated, and end up landing on your head.
I have had trouble with these units before, so this is the basis for the suggestion, good luck
Old 06-23-2004, 10:46 AM
thanks for the suggestion...i'l check the exhaust
Old 06-23-2004, 01:08 PM
geozukigti geozukigti is offline
I'd go with the cat too. But it's also likely that you may have dropped a cylinder for some reason. Makes the engine run really shaky. But the cat's in the metros are prone to clogging. And that would make it run like garbage too.
Old 06-24-2004, 09:24 AM
spark plug wire somehow worked itself off the distributor cap and it was only running 2 cyl. fine now
