Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 06-23-2004, 09:10 AM
dewald dewald is offline
Radiator fan not switching on
Hi guys!
Does anyone know where the temperature switch is located that's supposed to switch on my radiator fans when it gets too hot?
I know the fans work cause they go on when I use the aircon, but for some reason not when the engine gets hot. Any Ideas what else I can check for? I also couldn't find the fuse for the fan. It's a 97 model sentra, sr20de.
Thanks.
Old 06-25-2004, 07:59 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: Radiator fan not switching on
You should find the water temperature sensor under the inlet manifold. If your temp gauge is working, then it is working correctly so your EFI computer or fusible links to the fan are probably responsible for the fans not switching on.
Have you tried holding the engine at 4000rpm for prolonged periods to see if they turn on?
Old 06-28-2004, 02:37 AM
No I havent tried that yet. what does it mean if they turn on then? Thanks for the help.
Old 06-28-2004, 06:00 PM
rdobbs rdobbs is offline
Dewald, I had a 93 sentra doing the same thing. all fuses were ok. Rather than going to a lot of expense I wired the fans so that when the key was on the fans were on. That cured my problem and I ran it another three years with no problems before trading.
