Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 06-23-2004, 04:22 AM
quack quack is offline
Angry 2002 pk3 key
2002 montana owner manual says i need 2 original keys to programe the new key is there a way with just one key. how can you tell theres a chip on the key theres nothing stamp pk3 on it.bought at the dealer.
Old 06-25-2004, 10:48 AM
block3 block3 is offline
Re: 2002 pk3 key
All Montana's I've done only require 1 key to program. I've heard of some in Canada require 2. What's the first digit in your vin #?
There's equipment out there that will Clone your key. Basically it copies the code from your original key and programs it onto a read/write chip in the duplicate key, and requires no on board programming. Most automotive locksmiths will have this equipment
http://www.hightechcarkeys.com
Old 06-26-2004, 03:52 AM
Re: Re: 2002 pk3 key
first few digit in vin #? 1gmduo3e12d i check with dealer said it was the right key cheeper version 49$ can
Old 07-15-2004, 09:06 PM
navman911 navman911 is offline
did you manage to program it with only one key?
Old 07-16-2004, 06:57 AM
Re: 2002 pk3 key
no not yet. i checked with the dealer said it will take about haft hr to 1 hr to program at 60$ hr + tax i mention the programing should be included when you buy the key he just said yeah. still searching for a way.
Old 07-16-2004, 07:12 AM
My key is on the way from ebay. I bought it for 14.99 us. I will attempt to program it as directed in the manual (i only have one master key however and not the two that the Canadian vans need)
As soon as i get it and cut it, i will let you know how it goes.
Old 08-04-2004, 08:51 PM
Re: 2002 pk3 key
I got my key today from mylocksmith on ebay. I got it cut at a hardware store, followed the programming instructions even though it is a Canadian van it worked.
I saved $80. Canadian.
Thought everyone should know
Old 03-20-2005, 02:03 PM
GMRC GMRC is offline
PK3 Key-Canada
hi..when i bought my 2001 Montana last year I only got one key with it also.I had another key cut at the local dealers (cost $72.00) and programmed it myself.The owners manual tells you how to do it. I had to start my van with the Original key, then turn it off and insert the new key into the ignition within 7-10 seconds . I had to turn the key on without starting the vehicle.It works fine .I'm in Ontario,Canada and the dealer insisted I would need both keys to program a new one...I think its a money grab.The Owners manual gives instructions on how to program the key properly and says you can program up to 4 keys this way.
