Old 06-23-2004, 02:02 AM
crazyclown crazyclown is offline
Banned
just an idea.....
hey,
i came up with a thought yesturday and it might work. what would happen if u made a car with 2 engines (exactly the same model)
with 1 engine for front 2 wheels and another for the back two.
what would it do? would it work???
is this a good idea or am i ?
Old 06-23-2004, 07:47 AM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Re: just an idea.....
not a good idea, youd run into all kinds of problem with the front pulling the back some, or the back pushing the front, etc. bearings would make you about bankrupt i think.
its been done before though:
http://www.hotrod.com/thehistoryof/92018/
http://www.oldsmobility.com/hursthairy.htm
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
- Galileo Galilei
Old 06-23-2004, 08:24 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Car and Driver magazine did this in the late 1980's with a Civic. If you can locate a copy of the particular issue it makes for an interesting read. Front wheel drive cars lend themselves well to this because a second engine and automatic transaxle is relatively easy to install in the back. However, you need huge amounts of engineering and fabrication skill, lots of money and time to do it.
Old 06-24-2004, 01:13 AM
Banned
i know ud need a crapload of money, but its just an idea.... the next step is pulling together that much money
Old 06-24-2004, 01:30 AM
lazysmurff's Avatar
lazysmurff lazysmurff is offline
Send a message via AIM to lazysmurff
a twin engine tiburon actualy made an appearance a few years back in SCC's shootout and did pretty well for itself
i love him whose soul is deep, even in being wounded.
Old 06-24-2004, 07:38 PM
DJJC DJJC is offline
Re: Re: just an idea.....
What a load of shit. engines dont dictate the rmp of wheels, they provide a force. the ground speed dictates the rpm of wheels. its just like having a 4WD setup with a bias towards one set of wheels. sure, if you jacked the car up, the wheels will turn at different speeds, but thats because its not on the ground...once on the ground, all wheels turn at the same speed and have the power delivered as such the bias's intent.
ive also seen a few cars do it, with good results. ive heard of some pikes peak hill climb cars using this architecture before with good results.
Old 06-24-2004, 08:19 PM
MagicRat's Avatar
Re: Re: Re: just an idea.....
CarSuperfreak raised some good points. It's clear that you do not understand how force and power applied to the rear or front of a car can affect vehicle dynamics.
The concept here is synchronising the engines, their shift points (auto trans) and power to optimise vehicle handling.
In a single engine AWD car, one can design a transfer case to do this. In a 2 engine car, its more difficult.
For example. If you are going fast in a corner and one engine shifts gear before the other one does, the power output will change in an unexpected manner and upset the balance and control of the chassis.
Therefore, with all due respect, never call someone elses idea a 'load of shit' when you don't even grasp the concept at hand.
Old 06-25-2004, 07:07 AM
thanks MagicRat
and you bring up the best point of all; the transmission(s)
I havn't done a lot of research on this, but it would almost seem that you would have to have a single transmissino to avoid for aforementioned problems.
So im curious, do any of you know how they did the powertrain on any of these cars? (the 442, civic, tiburon)
- Galileo Galilei
Old 06-25-2004, 07:59 AM
Banned
why does every1 think its so complicated?
if u have the same engines hooked up to the same accelorator theyll both do the same thing
or at least i think.......
Old 06-25-2004, 08:11 AM
accelerator isnt the problem. on newer engines the throttle is either lectronically controlled or by a cable running to the accelerator pedal. The problem comes in that on the back of every engine, the crank has to connect to the flywheel, toque convertor, and transmission. and like magicrat said, to get the transmissions to work together would be a feat in itself. So i'm not saying it isnt possible, but it certainly wouldnt be easy.
and with the money you would spend on a twin-engined car, you could put into a normal drivetrain car, and it would beat on the twin engine car all day long
- Galileo Galilei
Old 06-25-2004, 07:27 PM
MagicRat's Avatar
As I recall, the Car and Driver Civic just had automatic transmissions. They tuned them to coordinate shifts as best as possible. However, it would be possible with electronic controlled transmissions to get them to shift at the same time.
A 2 engined car would be more attractive for a 'gee-whiz' factor, as opposed to having a practical performance application
Old 06-26-2004, 07:29 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
It would also be heavier than a conventional vehicle.
Beer tastes better upside down.
Old 06-26-2004, 07:53 PM
public's Avatar
public public is offline
Check this out. Funny as hell. Done on the cheap but it looks like a blast. How long will it last??? I don't think it was made for road trips :-)
http://www.ebaumsworld.com/reverseracing.html
Old 07-19-2004, 06:59 AM
Living5hrapn3l's Avatar
Living5hrapn3l Living5hrapn3l is offline
The Audi Bimoto has two engines @ 300HP each and Dubsport in the UK have built a MkII VW Golf with over 600HP that does 0-60 in 2.99secs and the quarter mile in 11.25secs
Programming today is a race between software engineers striving to build bigger and better idiot- proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rich Cook
