Old 06-22-2004, 10:15 PM
happyguyy2k happyguyy2k is offline
Angry power window
My 2000 Tahoe (new body style) is having a problem with a passenger side rear power window not wanting to roll up or down. Its not making any noises at all. Any suggestions? It has in the past done this two other times but started working again out of the blue and it quit again.
Old 06-23-2004, 05:10 AM
aero246 aero246 is offline
Re: power window
Pull the switch and check your connetion. Unplug and plug in again. If no response get a test light and see if you have power to hot wire. If have power then either switch or window motor is bad. If no power then check fuse panel for power and fuse.
Old 08-09-2004, 01:03 AM
Willie0508 Willie0508 is offline
Re: power window
also check and see if it is in the tracks i have a 2002 model and it does the same on the front passanger window but when i get it to rool up ther will be a gap at the top i just roll it down a lil and pusher in it does it ever now and then but no big deal be for u try what he said if it dont work for ether button the drivers then that prob not it
