Old 06-22-2004, 10:13 PM
bensaccord bensaccord is offline
Send a message via AIM to bensaccord
Check engine code 71 & 72
OK, check engine light came on sunday morning on my way to work. Car started to stutter and misfire. Made it home and my dad checked the codes out. 71 & 72 are random misfire in cylinders 1&2. Possibly caused my many different things.
Ran fuel system cleaner, still misfiring, removed the MSD and Blaster coil, still misfiring. Oil is good, coolant is good, plugs are good, Distributor cap and rotor are good. Could this be cause by the Map sensor and IAC Valve going bad?? If so, why would it only affect 1 & 2??
Mods are Intake, Exhaust, Header, MSD w/ blaster coil, underdrive pulleys, plug wires, plugs, grounding wires. Completely stumped, any help would be appriciated.
99' Honda Accord LX Sedan
-DC Headers
-AEM CAI -MSD 6AL w/ Blaster 2
-Unorthodox Underdrive Pulleys -NX Kit (50 shot)
-Accell Plug Wires & Denzo Iridium Plugs -#1 Tanabe Exhaust
1/8: 9.998
1/4: ????
Old 06-23-2004, 07:23 AM
HONDA_99 HONDA_99 is offline
Re: Check engine code 71 & 72
how do you know that spark plus are good?
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 06-24-2004, 06:40 PM
Turns out not ALL plugs were good. Mechanic checked it out yesterday and the #1 plug was totaled. Looks like it slapped the piston. Somehow the timing belt jumped two teeth and then smack, there goes plug.
-DC Headers
1/8: 9.998
1/4: ????
Old 06-24-2004, 08:21 PM
how engine sounds? there is any unusaul noises?
i concern about piston hitting valve and bending them.
Old 06-25-2004, 03:12 AM
I was concerned about that too. But it turns out there was no damage other than the spark plug.
-DC Headers
1/8: 9.998
1/4: ????
Old 06-25-2004, 06:58 AM
If there is no damage to valves conceder yourself lucky. And mechanic that did your timing belt should conceder himself lucky too.
