Go Back   Automotive Forums Car Chat > Automotive Art > Sketching and Drawing
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-22-2004, 10:02 PM
AnsisK's Avatar
AnsisK AnsisK is offline
My Marker TUTORIAL!
To start off this tutorial, I will show you exactly what I use to draw my drawings.
A – PASTELS. These are simple chalk pastels. I’ve got a beautiful variety of colours there. Make sure you’re not working with oil pastels. Have a roll of toilet paper handy. I will get to the procedure later on.
B – Micron Pens. I guess you can use other ones, I have 2 sizes 01 and 03. I like having those, but at this size of paper, I’d like to also have a 04 or 05.
C – Erasers. Here I have two of them, one regular Staedtler eraser, cut up. I cut it up to that size so I can see what I’m erasing, the eraser isn’t covering up or blocking any light. This way I can also trim the corners to be very sharp, to erase little areas. Notice the Blue eraser. I’m not sure on the exact name, but yeah, that’s what it looks like. It’s rather soft and you can shape it to whatever you want.
D – Standard pencil. HB, anything goes. I prefer the feel of a real one, mechanical pencils are too thin, so you can’t put down a nice thick line, and it is harder to get the darker tones. The pros use Prismacolor Verithin pencils.
E – Compass. For the newbies out there, you can use this tool for making nice easy circles, but that method really should be forgotten, it won’t get you anywhere. Draw circles freehand! If you’re scared their quality will bring down the entire drawing, than take out a fresh sheet and draw a million circles. The reason I included this tool is to use the nice sharp pointy bit at the end of the arm.
F – Inspiration!!! I use this book (Design Cars like a Pro, Tony Lewin) because it is full of beautiful drawings and designs that aren’t yet outdated. This gets you going, gives you ideas as well. A car magazine is also good. Whatever gets you inspired.
G – MARKERS. I use Prismacolors and Trias/Letrasets. Most markers are good, you don’t need much, just a light colour and a dark colour. Then add in all of the necessary ones, and you’ve got your surgeon’s kit. I primarily use one or two colours, Warn Grey (though cool greys are better) 10%, 20%, 30%, 60% and 90%. Black is good, and I use Tuscan Red for tail lights. Other than that, the markers are up to you!
H – PAPER. Letraset Marker paper is the way to go, but I’m a poor little guy and I don’t have the money to get it, so I’m using regular sketch paper. Since my drawing will be big, the bleeding isn’t as noticable as on a sheet of printer paper. ‘Go big or go home’ in this category.
Okay. That covered, I will lay down a simple one-point perspective design. I’m not writing a design tutorial, so I won’t go into this section too much. Keep loose!!!
1. Draw the ground. a STRAIGHT line connecting each end of the paper.
2. Draw in 2 wheels. These don’t have to be perfect at any rate. They will surely change later on when you draw in with ink. Keep in mind wheel bases. I shouldn’t have to remind you, keep 3-4 wheel sizes between the two real ones. We don’t want a cartoony result, so get a respectable wheel base down. Also when drawing the wheel, you should definitely know what style of car you want. Make sure to incorporate front and rear overhangs. With that in mind, draw the wheels as close to the edge as possible, that way your drawing is bigger, which is important.
3. Starting from the top of the front wheel, make a shoulder line. It should end above and past the back wheel. Up to this point, you don’t need much talent, it’s straightforward. Have fun!!! “A common mistake when learning is starting a new drawing when you realize something is out of place. Don’t! Continue with the drawing, using the mistake as a guide in sorting out the problem.”
4. Now the tougher parts begin. You want to draw in the main aspects. Start with the window. Keep in mind its size, height, and where it will be in relation to the wheel arches. Now put in more basics, roofline, add the front of the car and the back of the car. These will be the rough proportions of the car.
5. Bust out the pen! you want to darker the roofline ad the windows, these areas are where you want the viewer to focus. Careful now, you can’t erase marker! I used my Micron 03.
6. Now, draw in more details. Before you make any more serious commitments, check your rough details by putting up your paper to a light source and checking the drawing from the other side. This will uncover plenty of mistakes. The main parts and places you like should be darkened. Where the windshield meets the hood and the rear window meets the trunk lid should also be prominently darkened. Don’t pen in the wheels yet. Their position is important, so they should only be added at the end, so you can have them wherever you want. You be the judge in what major things get darkened. Keep in mind that what you erase has to be somehow included in the final colouring.
7. Okay, here is an important step. Draw in where you feel the reflection of the horizon should be. On a rounder-sided car, this line is lower down. On a slab-sided car, this horizon line is higher up, almost touching the shoulder. I have this sort of MR car that really is in between, so I have it comfortable sitting below the shoulder line. Don’t forget you pillars! I separated this from step 6 because I feel it isn’t part of the line drawing. Steps 1-6 are up to you, but this last one is important.
8. Erase any big mistakes you made in pencil. I like to keep the main lines, because they help the pen define the main components of the car. You end up with a sketchy feel. I made a mistake in the front nose, I can clearly see it is too short and stumpy. That’s okay though! Don’t give up. I will make it bigger somehow (later in the drawing, when I feel that adding a darker section will look okay). For now, I’ll just leave it as is. Here is what I have at this point, and I can take a brake.
9. Chose a pretty colour. Make sure you have a pastel that matches that marker, or else you’ll be mixing
them, which doesn’t always work out.
10. Okay now that we have chosen a pretty colour (a plain yellow in my case). Now I will blotch in everything below the horizon line with a first coat of yellow. That step can be done slowly, I personally hold on to go wild with the colours til a later step. Tada!
11. Now by adding more layers of marker, you can add a gradient effect to the previously existing slab of reflection. I have a little intake in front of the back wheel, so I’ll make sure that I also darken that area. So far, it’s pretty straight forward. Remember to also curl the reflections on the sides, see? On the extreme left and right, I also darkened it up, that is how reflections work on real paint, sometimes . Notice how in front I have already started correcting my mistake? I used the old line to judge where the new one should be, and I will continue to gradually fix it. For the next few minutes add more and more gradient, but keep calm. I personally let loose in the next step
12. Okay here is where I get my “motion” effect. I am going to take out my black marker, and add thick lines along the horizon. This will tremendously darken up the drawing and give it a sketchy look. It will also make the reflection feel more reflecty. That took a good 30 seconds. The rage is building inside me at this point. Most designers probably would disapprove of step 12, but I like it. At this point, you might say my drawing looks a bit dorky, but hey, I’m a dorky kind of guy! Actually, I’m just kidding. I’m cool! Sorry, it’s been a looooong day. This droky black will be exploited in the next few steps to add “motion”. (EDIT: Don’t go too much on the black, like I did)
13. The anger is building inside me, and I’m about to set it loose. I suggest drawing while listening to music, it alters your train of thought quite dramatically. I chose Rage Against the Machine to draw to, and I think it kind of works. Boom! Here I come. Pick up your marker, and make that black wish it was never there! Destroy it, but essentially make it bleed one hell of a lot! Instead of going left to right, go up and down, this way, it drags the darkness of the black down into the yellow, adding gradient. Hold the marker strong and press down hard on the paper. Let the marker puke out the ink so it maximizes the black’s injuries. This is white knuckle drawing at its best!
That basically describes the main marker portions. Now clean up that anger, it will only wreck the drawing if you go reckless. And look what happened! The wee little ugly nose transformed into a strong gracious swan!
(EDIT: It still looks small, oh well!)
14. Alright. Now Here comes the trickiest part. Take those pastels out and take the compass out. Draw a line on the corner of your page, using your marker used on the paint. Now open up your pastel case and chose the 3 closest pastels to your marker. Using your compass (or Xacto, anything sharp) scrape off the pastel a little pile of powder next to the stripe of marker.
Then take a little bit of toilet paper and gently smudge the powder so its now on the paper.
Do this with all of the closest chalks. Then put back the worst ones and only use the best one. Okay, now here’s the problem. You will run into a situation where you just don’t have the right colour pastel. This is a problem. Okay, let’s say the pastel is too dark. Scrape off a large pile of that colour, and take out a white pastel. Grind off some of the white (enough to balance the colour to what you need) and mix it thoroughly using the pick/compass or even a credit card. Now that you have made your choice, take that pastel and grind it our all over the paper in the appropriate spots. If you had to make a home-brew pastel powder, than apply the powder by dabbing it with the toilet paper. Don’t worry, it will smudge all over the drawing but thankfully you can erase this stuff! Sometimes when you’re working with a light pastel, you will find that the powder just isn’t enough. In that case, just downright draw with the pastel onto the paper, and lightly smudge it away. If that’s not enough, just cheat and use a bit of marker (see my drawing ). Keep the little bit of toilet paper, it has a fairly nice layer of pastel on it. Smudge it all off into the markered areas of the sides to fill in any so-so parts.
15. Now the easy part. Erase lights, upward facing objects (mostly along the shoulders), windows, wheels wells and any other place where the pastel got smudged onto.
16. If you’ve gotten this far, good for you, I hope this hasn’t been too hard. Now we shall do the windows. There are numerous themes you can use. Now that you know my secrets in gradients, check my other drawings for ideas. Make sure to keep it SIMPLE! I cannot stress how important it is to keep it simple and uncluttered. For this drawing, I’ll only do a simple, design-friendly reflection effect using 2 markers, Warm Grey 30% and 60%. The 30 I will be layering a LOT, so maybe use a 40 or 50. Okay. Draw the line of reflection, somewhere near the middle, maybe a bit towards the top. Have the bottom be darker. The rear and front windows should also be in this same shade. Notice by doing this, you are creating another horizon reflection on the side? Okay, now darken those significantly. Like I said, this is just one way to do a window reflection.
17. WHEELS. Okay, this is probably the most time consuming part of the entire drawing. If you’re lucky, you will still have the original pencil lines from waaaaaaaay back in step 1. Pick up your pencil again and draw in a better line. Here it is important to keep in mind ground clearance and wheel size. These two factors alone contribute to the realistic/non-realistic sketch. The wheel itself is COMPLETELY up to you, but if you are branding the design (I’m not) then make sure to design them accordingly. They also don’t have to be completely functional, just look cool. That is the effect I’m going for right now. Darken in the areas outside of the wheels (wheel wells) with a black. This is your chance to make your wheel well’s edges smoooooth. But be careful doing this, you might end up taking too much off the car body, which is bad. Draw in the remaining wheel edge with a pen. And we have a shape! I personally am working on an idea sometimes used by designers, that is, to leave the base of the wheels open, making a continuity between the car and the ground (almost as if it’s on water).
18. Alright, now let’s go wild with the wheel design. They don’t even have to have tires! I’m just gonna make something up, inspired by Italy. I’ve seen something like this on Alfa Romeos and on the old Countachs, but my design won’t have a wing on the front.
I’d suggest that you draw a set of your wheels on another piece of paper. The amount of mistakes in your first try is incredible. By your third and fourth time drawing them, you’ll be drawing the right effects flawlessly. As you can see, I’ve been rushing to get this tutorial out so I just went ahead like that, so I didn’t end up with the concave effect I wanted.
19. DETAILS! Take each area of the car over again and go through each little bit again, make your reflections sharper and everything straighter. In general, go though each bit and go over it ALL, redo every bold line. Here is the stage where you draw in the tail lights and the headlights. Details like that got left out earlier (steps 1-6) should be thrown in now. Be careful not to bleed anything that you just added!!! Okay now you should add any effects you want, like a backdrop, a squiggly line or something. I usually do this to have the drawing pop out at you. Remember, nothing that will drown the drawing out completely. If you are against such artistic-boxes-in-the-background and other little effects, just make sure you have an undershadow. On my version I simply added a ground effect.
20. POST-DRAWING! Here is the section where 2 major things happen. First thing is PHOTOSHOP!!! I strongly urge the entire art world to avoid this program for completely redoing your car. That is cheating in my books What I do is scan the drawing at 300dpi, Add 14% contrast and erase and left-handed-smudges away from the outside of the drawing. Nothing else. I add that contrast to portray the EXACT drawing that is on my paper. No doubt PS is an epic program, but for car drawings, I like to go lite with it. You could, for instance, add two lenseflares located on the horizon reflections (lightsource?). Check that effect on my Ford GT (ha) design. Mind you, this effect is perfectly feasible through white chalk pastels. The second of the After-drawing is doing what all of us do on AF, Cardesignnews and other sites. Ask for crits and comments, learn from your mistakes and avoid them in the future. If it weren’t for the help of generous people around the internet, I’d be drawing little POS cars. Maybe not even designing. For my own comments, Next time I’ll avoid using so much black (looks like a tiger stripe on the C-pillar). I also see that my MR designs are featuring more and more bubbly greenhouses. In general this design is too dirty, I don’t like the black I added.
HERE IS THE FINAL PRODUCT! If you compare this and step 8, you can see so many changes in the actual drawing. This is partially why I wrote the tutorial, to show how markers can change a drawing dramatically.
eliseracer
Old 06-22-2004, 10:05 PM
AnsisK's Avatar
Re: My Marker TUTORIAL!
I am hoping that everyone will use and enjoy this tutorial I urge you to show me the results if you try it! If anyone sees anything that is unclear, should be changed or is wrong, PLEASE NOTIFY ME! Thanks all, I hope you buggers enjoy it, it took me all afternoon to prep!
eliseracer
Old 06-22-2004, 11:05 PM
you you is offline
wow, thats long.
You's Truly!
Old 06-22-2004, 11:54 PM
tokes99's Avatar
tokes99 tokes99 is offline
Although I can not really say I am feeling the final product, I definitely appreciate the time spent homie.
A couple of notes:
1. it is a good idea to go from light to dark, so when outlining try to go pretty light, or else you will likely get blotches over darker areas.
2. instead of going with the black you can use a cool gre/ay (about 30%-60%) or a darker shade of the same color. Supposedly you can get a couple of shades from one marker.
Great tutorial, remember there is not a right/wrong way to render
yes, I am a newbie now let the flames begin
Old 06-23-2004, 12:48 AM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Added to the Tut section. Thanks AnsisK!
MAKE ART, NOT WAR
Old 06-23-2004, 12:59 AM
lemorris's Avatar
lemorris lemorris is offline
Send a message via AIM to lemorris Send a message via Yahoo to lemorris
do you add any prismacolors in the end? or maybe guache? Something to puch out the whites or dig deep on the dark end?
When you get your hands on some letraset. Try adding your black or dark grey in step 12 on the backside of the paper. This way it won't intrude, and you can continue to add color on the top side without the black beating it up.
I like your style. Do you have any rods?
oh!! you try frisket?
http://www.lemorris.com
Old 06-23-2004, 01:01 AM
AnsisK's Avatar
Yeh the black can be replaced with a darker colour marker (I mentioned that in the meterials section maybe). I like the black because it adds a crap load of contrast and makes it sketchier. I'll try with a 60% though.
The final product was also pissing me off. I was actually going to rescan everything, but I finished at 10PM, so I really didn't feel like redoing it all. It may also look pointy in the back because I had to stretch it, For some reason the original scans weren't good.
If the stepover is bothering anybody, just check out my other sketches. All of my marker stuff recently was done EXACTLY this way.
eliseracer
Old 06-23-2004, 01:08 AM
AnsisK's Avatar
Re: Re: My Marker TUTORIAL!
No, it is all done with markers. I did boost the contrast +10 in Photoshop. This was only to try to get as close as the original as possible, I put the paper up to the screen and they matched pretty OK. For the darks, I have a number of layers on everything, even on the blacks.
That is a very interesting point, I'll look into trying the backside thing.
I don't draw old cars, sorry
eliseracer
Old 06-23-2004, 02:12 AM
Benjibunni's Avatar
Benjibunni Benjibunni is offline
i'm gonna try, i was having trouble, but this seems to have helped
Old 06-23-2004, 05:24 AM
Ra_15's Avatar
Ra_15 Ra_15 is offline
Send a message via MSN to Ra_15
Thanks ansisk! The nose needs to be atleast twice that length, but you allready said that. I like the wheels!
My first car drawing, wish I could still draw this well
My Gallery
To draw with a broken pencil is pointless.
Call me Ross.
Old 06-23-2004, 09:47 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Thanks Ansis! I'm going to try it out sometime when I get ahold of some markers.
-Mike
Old 06-29-2004, 12:12 AM
AnsisK's Avatar
Hello people! I don't want to sound rude, but at least 3 people asked me for this tutorial, and I did it. It also took me a good 6 hours. Did anybody even try it? This shouldn't take more than an hour to draw!
eliseracer
Old 06-29-2004, 02:25 AM
castback's Avatar
castback castback is offline
Send a message via AIM to castback Send a message via MSN to castback
hey dude i tried it only i didn't try it on a concept. i tried the coloring on a mustang. thank you very much for all the time you put into this tut. thank you
Old 06-29-2004, 08:37 AM
AnsisK's Avatar
Could I see the result?
Thanks.
eliseracer
Old 06-29-2004, 10:04 AM
mike@af's Avatar
Im in the works of buying some prisma's...Be patient, I need a new MIG and TIG welder first.
-Mike
Closed Thread
