Old 06-22-2004, 08:57 PM
JohnyChevyEG JohnyChevyEG is offline
weird thing happens when idle
My 01 LX makes a weird noise, and the RPM guage fluctuates a little when idle. This is usually after driving for a bit and then coming to a complete stop. WHen the lights are on, I can see the lights flicker when this happens as well. The noise sounds like a hum. It comes and goes. It will fluctuate rapidly for a few seconds and then start up again. Any thoughts?
Old 06-22-2004, 09:00 PM
I guess i should say that when the rpm guage drops, I feel a slight vibration as well. Thanks.
Old 06-23-2004, 02:32 PM
ModMech's Avatar
ModMech ModMech is offline
Re: weird thing happens when idle
Sounds like the A/C compressor cycling. When this is happening, turn the HVAC to the "OFF" position, and if it is the compresor, it will stop then.
Old 06-24-2004, 12:24 AM
Would it still do that even though I dont have the A/C turned on?
Old 06-24-2004, 09:34 AM
ModMech's Avatar
Yes, in Defrost and "mix?" the A/C system is energised, and will run based on temp.
As I recall, the ONLY two positions on a Ford that kill the A/C system are "OFF" and "Vent"
Old 06-24-2004, 11:54 PM
I have it on the off position and it still does this.
Old 06-25-2004, 07:37 AM
I think I have narrowed it down to thimes that it occurs. I drive the car for a little bit then stopped in my driveway with out lights or anything else on, and it wasn't noticable. As soon as I turned on the headlights, it started doing it. I turned them off, and it returned back to normal. I also turned on the A/C and on the initial click as it was turning on, the rpm guage dropped real quick and I heard the vibrations then it came back up. COuld this be some sort of electrical problem? I have an appointment next tuesday to get this looked at, but I this thing doesn't happen all the time so I would like to troubleshoot it this weekend and try to fix it while it's happening. I would appreciate any suggestions.
Old 06-25-2004, 09:40 AM
ModMech's Avatar
The "hum" might just be either the Idle Air valve resonating (which would explain the variable idle), a Power steering resonance (but that should NOT happen unless you are turning the wheel), or a belt tensioner/idler which is due to changing load on the belt system (alternator load, A/C compressor, P/S pump, etc).
Old 06-26-2004, 06:20 PM
How could I check these things. Sorry, I'm an extreme beginner when it comes to car work. I would like to become more interested in doing my own repairs though. Thanks.
Old 06-27-2004, 12:18 PM
ModMech's Avatar
Well, if you step on the throttle, and the noise goes away, that points to the IAC solenoid. If it does not, then you remove the drivebelt and briefly restart the engine, if it's silent then you shut the engine off, remove the key and spin all the wheels that run against the belt to see if any are rough or make noise. Replace any that are noisy or rough (which should be done even if itdoes not completely solve your problem).
Old 06-27-2004, 02:57 PM
would the IAC still be the issue with the lights dimming when the rpm's are dropping as well?
Old 06-27-2004, 05:32 PM
ModMech's Avatar
Sure, if the RPM drops becaues the IAC cannot maintain it properly the Alt output will also drop, lights will dim etc.
Old 06-28-2004, 04:39 AM
i seriously think thats it then. When I press on the gas even just a little, my problem goes away. Now, how can I fix this issue? Where is this thing located?
Old 06-28-2004, 07:44 AM
Nevermind, I found it. SHould I just attempt to swap it out? Or can I just clean it?
Old 06-28-2004, 09:59 AM
ModMech's Avatar
You can clean it, but you have only about a 25% chance that it will be worthwhile. For $40, just replace it, and PLEASE use a Motorcraft replacement, the aftermarket stuff is truely not as good and costs just as much.
