Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 06-22-2004, 08:32 PM
hang10 hang10 is offline
Question battery keeps dieing
how can i fix this problem every sence we bought the car 2 years ago and it is a 1997 dodge stratus. the battery keeps on dieing how can i make it stop dieing. Is a fuse shot or is something shorting out. when ever i turn the car off i turn the radio off the the interior light off. let me no if any of u people have this problem with the status and if the year has anything to do with it. thanx
Old 06-22-2004, 10:12 PM
pegasus757 pegasus757 is offline
Re: battery keeps dieing
is the top of the batt moist, if so the moisture on the outside can cause the batt to drain (clean it). also the batt may be bad . when the plates inside the batt starts to shed ,that junk collects at the bottom and shorts out internally. here is a quick trick...start the car and remove the negitive batt term if it dies ,its not charging ( or use a meter 13.5 to 15.3 volts car running) too low batt does not charge .too high and your burrning up the batt.
Old 06-23-2004, 12:19 AM
it is a new battery. what about that red plastic thing if i cover the postive in with that would it make a differnce. I ahve a volt meter it cam factory in the car and i here it is very rare. it reads about 14 volts
Old 07-04-2004, 06:49 PM
Valenti56 Valenti56 is offline
Car dying/battery/fuse problem
My son also has a 97 Stratus that keeps blowing the #8 start circuit fuse (20 amp). He comes out to his car and it won't start....we thought it was a battery problem, but when we replace the fuses it works for awhile and then all of a sudden blows a fuse again. Any ideas what might b causing this???????
