Old 06-22-2004, 06:50 PM
tresten tresten is offline
ReProgram Your LockFOB
Hope this Helps You'all Out
1. Make sure everything is turned off (radio,CD,DVD,police scanner,GPS, blow up doll pump etc)
2. Turn ignition key on without starting truck
3. Do it again
4. Do it again while depressing both buttons on FOB turn off ignition remove key while still depressing FOB buttons(you never stopped depressing those buttons right) OK now let go of those buttons!! and put your ears to the test
5. You should hear your locks cycle
If you don't hear the locks cycle move the truck do it over because you're experiencing interference (which happens alot )Keep in mind this will not help dead batteries,the FOB you dropped in the lake, ran over with the wifes BMW, threw at the cat...........
