Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-22-2004, 06:08 PM
HpyGlmore HpyGlmore is offline
95 Camry Brake Light Problem
The light with lines by the back of the car is illuminated on the dashboard ( a brake light is out). I replaced the brake light that is on top of the trunk (inside the car), but that did not fix it. I checked all the lights in the rear. I count 9 bulbs total (the top one, plus 3 per side on the back, plus 2 bulbs used for reverse). All of these lights check out fine, but the indicator light still comes on when i hit the brake pedal twice. Any ideas? Am I missing a bulb somewhere?
Old 06-22-2004, 07:33 PM
gelcol gelcol is offline
Re: 95 Camry Brake Light Problem
same thing happened to my camry and at therear trunk when you turn the park light try to play the trunk up and down see if the lights go on or off? if does then short on yur wires near the left hinges trunk see a electrician normally cost $65.00 don't ever go to my area here in mission road Alhambra its a rip off own by an armanian guys$250.00
Old 07-18-2004, 01:16 AM
patmanj20 patmanj20 is offline
it also ahppened to my camry ('93), twice. first time took it to a toyota place to have it fixed. it was a wiring problem. they rewired it, giving it daytime running lights (corner lights), for $400. then it happened again, this time did it independently, traced the wire from the trunk lid and saw they were exposed and shorted. you'll have to redo that part of the wiring.
