Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-22-2004, 05:45 PM
sandslady2 sandslady2 is offline
Radio
Ok I have one for you. Why is it that when I have my radio on a FM station and I hit the rear defroster button my stereo gets all fuzzy. It doesn't happen on AM just the FM and just the defroster button effects it. I have a '99 Camry CE 4 cyl. Thanks!!
Old 06-22-2004, 11:14 PM
Joe W Joe W is offline
Re: Radio
The antenna is in the rear window.Is there anything blocking it?
Old 06-23-2004, 01:36 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: Radio
Not only that, you need to check the inside of the back glass and verify that there are no breaks or scrapes in the lines in the glass, also make sure that there is no metal grounding out the two different wires.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 06-23-2004, 08:06 PM
Erndog1369 Erndog1369 is offline
The antenna is bad in the rear window.... it's a fairly common problem. You'll need to have the rear window replaced to remedy.
Old 06-23-2004, 10:01 PM
Re: Radio
Now let's not go jumping into the assumption that the antenna is bad. There is a very good possibility that one or more of the lines in the glass could be damaged, and this can be repaired, rather than replacing the whole rear glass. All of the lines in the back glass need to be inspected for damage, and if there is one that is damaged, you can repair it yourself. Don't go replacing glass unless the glass itself is broken.
