Old 06-22-2004, 05:19 PM
croy croy is offline
Unhappy ebay halo projectors un upgradeable?
I just got a pair of these halo projectors for my 03 accord coupe. While they look very nice they came with these tiny little hb3 & hb4 bulbs. I thought at worst I would be able to use some piaa plasma's and at best a hid kit. Does anyone know how to upgrade these to use better bulbs or an hid kit?
Old 06-23-2004, 05:02 PM
V6GUNZ V6GUNZ is offline
Send a message via Yahoo to V6GUNZ
Angry
I feel you pain bro, i had the same prob with my 01 accord, the problem you will run into is that a good HID kit will cost you a pretty penny, now the other problem is that you are limited by the amount of room INSIDE the socket that the regular bulb fits in, you just need to shop around and compare sizes, be carefull that if you do go with HID's that they don't run too hot or you will melt your housing, or parts of it, it happened to a friend of mine. another problem is that alot of companies use cheap foglight lenses instead of projector lenses so the beam patters is all irregular, so they will not illuminate as well as your stock units. im speaking from experience, if the HID kit you buy is not simple bolt on so to speak, you will be paying more for some customizing.
Old 06-23-2004, 05:36 PM
Cool
Thats the thing, you cant even use your stock 9006 bulbs in the new housing(back side of projectors). They only fit these little hb4 bulbs which dont even look like they are made for cars and I'm wondering what I will do if one burns out. As far as hid kits, they have come way down in price. I saw these ruby purple 1200k kits on ebay for like $320. I know some of you think 6000k is as far as it goes. But Dam the images the seller had of the way the kit looked.....I was very tempted. I think it will take anoter aftermarket housing that can replace the housing made for these little hb4's. If any one has done it let me know.
Old 06-30-2004, 01:44 PM
Accord_99 Accord_99 is offline
Send a message via AIM to Accord_99
Hey, I have a 99 honda accord with the Halo projectors with 8000k HID system and they work pretty well...Only have one problem with the Halo Projector Headlamps...you can adjust the light beams (and if you know how..PLEASE let me know how!) Also, in order for you to make the "halos" work, you have to tap it into your headlight wire...I haven't done it yet for the reason of I want to make sure that is the only way before I mess around with the main wire of the HIDS..haha...
Old 06-30-2004, 01:45 PM
Re: ebay halo projectors un upgradeable?
eer...typo...you CAN'T adjust the light beams...there is no knob to do so like on the stock headlamps....
Old 07-07-2004, 04:35 PM
jumpa's Avatar
jumpa jumpa is offline
i think there are three screws in the back of the projector housing u can use a flexible tube philip screw driver to adjust it...it's kind of hard to do but that's how i adjusted my light beams.
>01 Sil Accord Coup
>AEM CAI/NGK irridium spark plug/Royal Purple oil 5/20
>projector headlights w/rims/altezza tail light
>Brembo drilled/slotted rotors painted calipers blue
>19" excel DL-46 225/35 toyo proxec tires/2" Intrax springs
>ingall camber kit/Mugen Front lip/aluminum dash trim
