Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-22-2004, 05:01 PM
salchichon20 salchichon20 is offline
gsr ecu
does a 95 gsr ecu connect directly into a 95 honda civic ex wire harness or do i have to buy a another wire harness ? thanks
Old 06-23-2004, 03:54 PM
YellowITR479 YellowITR479 is offline
Re: gsr ecu
probably does but im not sure....2 different engines....why do you want to put a GSR ECU on a EX car.....i dont even think it would work...one's DOHC and one is SOHC.
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-23-2004, 04:01 PM
oh i forgot to put some info i have a b16a in the 95 ex and want to know if the p72 (i think it is) fits on the 95 ex wire harness
Old 06-23-2004, 04:02 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: gsr ecu
Yeah if you're doing a gsr/b16 swap then it will plug in fine, but you'll have to add some wires; I know the knock sensor is one of them but I can't think of the rest.
Old 06-23-2004, 04:04 PM
Re: gsr ecu
thought you had to swap harnesses?
