Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-22-2004, 04:10 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Truck tires...
my 97 silverado is in need of a new set of tires and what it has now is 265/75-R16, now i dont entirely understand all that ratio mumbo-jumbo but as far as i can tell that is close to 32x11.50. i was wondering if i could fit something that would be 33x12.50, 33x11.50, or 32x11.50 without rubbing. would that be close to 285/75-R16 or 305/85-R16? cuz most all the tire sizes for a 16 inch rim is incripted in ratio....
Old 06-22-2004, 05:28 PM
CapriRacer CapriRacer is offline
Re: Truck tires...
It's actually even more complicated than that!
Your truck came with P metric tires - on 7" wheels. All the sizes you mentioned are LT's.
If you are planning on using your stock wheels, I'm afraid the size you have - P265/75R16 - is the largest that will fit.
If however you are planning on changing wheels, here's a calculator to help you with the diameters and stuff.
http://www.1010tires.com/TireSizeCalculator.asp
Hope this helps.
Old 06-23-2004, 11:17 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
Re: Truck tires...
Yes, they maxed the tires out on that rim package from the factory. Anything in the 33" rang will require a lift kit of some sort.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
