Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 06-22-2004, 03:17 PM
sjones1025 sjones1025 is offline
Send a message via MSN to sjones1025 Send a message via Yahoo to sjones1025
I have a Stereo Question....Please HELP ME!!!!
Hi there- I need help....I have a 2001 plymouth neon, and I have an eclipse stereo, nothing fancy just a CD player, it's an in dash. Okay here is what I did! I disconnected my battery, once I hooked it back up I have an error on my stereo now. It will not power on...does anyone know....what the heck I do. I really, really don't want to go spend 75 bucks an hour for a guy to reset something, or change a fuse.
Does anyone out there know what I can do?
Thanks
Shannon
Old 06-23-2004, 12:44 PM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: I have a Stereo Question....Please HELP ME!!!!
Might not help, but check the fuses and your connections and make sure they're correct before you replace a fuse!
Sorry I can't be of more help than that.
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 06-28-2004, 02:29 AM
Imacarharrtcowboy Imacarharrtcowboy is offline
Don't know a whole lot about stereos but i'll throw my 2 cents in. If you have an owners manual try trouble shooting it. Or call a repair store, sometimes they can help over the phone and it keeps you out of the position of having them look at your car. Check the fuse on the back of the reciever also.
Old 07-07-2004, 11:07 AM
RSLaser RSLaser is offline
Check your remote wire...usually its a blue one. If you wind up having to replace a fuse make sure you still have a good ground.
1991 Plymouth Laser RS
Only sat for a few years....
Old 07-07-2004, 11:10 AM
Check your remote wire...usually its a blue one. If you wind up having to replace a fuse make sure you still have a good ground. Check the wires behind the console with a light tester. Leave the car off, connect the pos tester side to the remote wire and the pos to a good ground somewhere non the chassis. then turn the key to ACC, the light should come one, if not check fuse or for broke wire. Lemme know if this helps.
Old 01-01-2005, 09:47 PM
smoove910 smoove910 is offline
On Eclipse stereos, once the power is disconnected you need the security disc to gain access. If you are the original owner of the stereo, then you should have that disc. If you are not the original owner, I suggest you contact Fujitsu/Sen (maker of Eclipse) and let them know your scenario... Good luck.
