Old 06-22-2004, 03:08 PM
dellga dellga is offline
302 valve adjustment
Getting ready to drop the 302 back into the 69. Had the heads reworked with hardened seats, polished and ported and new retainer studs. I'm not sure how to go about adjusting the valves from scratch. Any advise is welcomed. Thanks.
Old 06-22-2004, 05:46 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: 302 valve adjustment
start with getting #1 top dead center.... while spinning the pushrods tightin the rocker slowy until you feel tension, then tightin 3/4 a turn.... do that with every cylinder.. make sure there all top dead center b4 you tightin them and the lifters are all the way down and even
Old 06-22-2004, 08:32 PM
speedfreak's Avatar
speedfreak speedfreak is offline
Send a message via AIM to speedfreak Send a message via MSN to speedfreak
You didnt mention if you have stud mount or pedestal rockers as the adjustment methods are different.
For stud mounts you adjust them essentially how ridge_runner said, just make sure the valve you are adjusting is on the base circle of the cam and tighten down 1/2 to 3/4 turn.
Pedestals are a little more complicated since they need shims. Crane Cams has a good adjustment how-to on their site.
1968 Mustang notchback Roller 302, Edelbrocks, Hookers, side-exits, RRs, Crane 2031, Duraspark, forged slugs, X-Celerator, 650DP, Fidanza FW, RAM clutch, Toploader, Comp Plus, McLeod bell, 15x7s, 1 1/8 swaybar.
1972 Ford Pinto SVO 2.3 turbo, MegaSquirt, T5, 8", etc.
'95 Honda XR600-10.5:1, 628cc, ported head, & more.
