Old 06-22-2004, 03:01 PM
stapletonk stapletonk is offline
Lightbulb Stuck, can anyone plesae help!!
Ok, i just replaced my fuel pump this weekend. Got everything together and car ran pretty good with the exception of a lot of white smoke. Thinking the car has been running so bad for a month that a lot of carbon built up. Anyways, the 2nd day the car fires up great and the smoking problem seemed to have gone away. I was sitting at a stop light. CAr was idling with no sign of problems. Went to set on gas and the car dies. I try to resart car fires up and to about 2000 rpm and slowing dies. Didn't matter how much i pumped gas or didn't same effect everytime. I did replace the fuel filter before i decided to replace the pump. Going to try and replace filter again hope that helps. The car also haves a coolant leak into the intake, not sure if this would relate to this problem or not. If anyone has any suggestions I would appriciate it. Thank you for your time.
Kerry
Old 06-22-2004, 03:29 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
Re: Stuck, can anyone plesae help!!
LOL. geee i wonder.... you might want to try fixing that. oh and water in the combustion chamber, i wonder if thats a problem.
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 06-22-2004, 04:52 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Re: Stuck, can anyone plesae help!!
Old 06-23-2004, 09:03 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
yeah, the coolant leak is exactly your problem, probly fouled your O2 sensor(s), causing the engine dying, and running like crap. and other possible problems, coolant in the oil will also cause bearing and other failures.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
