Old 06-22-2004, 03:43 PM
is0crazy's Avatar
is0crazy is0crazy is offline
Send a message via AIM to is0crazy
I want more power from my 425
Just got a 79 Cadillac CoupeDeVille with a 425 and a TH-400. I want to up the power output but stay on a budget. (having a wife and kids doesn't leave much money for toys when you're living off of a Navy paycheck) Right now my plans are: intake,carb, headers, and since there is no emissions testing in my county, I want to remove all the smog equipment and any extra loads on the engine that I can. I can handle the first few things, but I need some help with the smog delete. If you've done anything like this, or know someone who has, please help me out. Thanks.
Old 06-22-2004, 08:04 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
You have the right idea with the parts, and if you had any other GM V8, it would be easy. However, your engine is a design unique to Cadillac and was built in various displacements (368, 390, 425, 429, 472, 500) from mid 1964 to 1981 (Note the pre mid-'64 engines were also 390's, but a completely different design).
So, no one makes the performance parts you want. There is one small company out east that makes them in small quantities for big $$$ A web search would likely turn up their name, I just can't remember it.
Otherwise your choices are:
1. Work with what you have. Tune it up and make sure everything, carb and ignition parts and settings are correct. Be sure to run ported vaccuum from the carb to the distributor. Many '70's and early '80's carbs had a thermal switch that selected manifold vaccuum at low engine temps and ported vaccuum at normal operating temperatures. These switches usually seize in the manifold vaccuum position making the engine run like a dog that won't pass a gas station. Install dual exhaust, with decent mufflers and no converters. Use an open element air cleaner, or better yet, modify the stock air cleaner to a dual snorkel type with two cold air ducts.
Remove the air pump to the exhaust manifold and block off the lines. Do you have EFI? That can be changed but requires a differnt fuel pump. If you have a Q-jet, just make sure its tuned properly and that the secondary air doors open when they should. Those carbs have a linkage to prevent them from opening when cold. Often, this linkage gets stuck, making the carb run like a little 2 barrel all the time. Theoretically the EGR valve reduces power, but if its working properly, it does not hurt performance much. You can make sure its closed, (not stuck open) and remove and plug the vaccuum line for it.
If you don't have aluminum rims, find some and toss the spoke hubcaps. I shaved 100 lbs of rotational mass off my Cadillac by using aluminum rims off a mid '70's T-bird (Lincoln ones work too,) and some low profile tires. If your AC does not work, remove the compressor, bracket and condensor. That saves another 60lbs.
2. Try another Cadillac engine. Your 425 has relatively small valves in the heads, so the performance potential is somewhat limited. Locate a 472 or 500 cid block. They are a straight bolt in and produce lots more power. A '69 or '70 has the best high compression heads of all, although those engines were made through 1976 in a lower compression form
3. Try a Buick/Pontiac/Oldsmobile engine. All kinds of performance parts are easily available for all 3 brands, although Pontiac parts are the slightly cheaper and most easily available. These engines will bolt right up to your transmission, and all 3 designs came in a 455 cid size, although they are each different in design. Use the engine mounts intended for that engine and its quite easy to weld them in place in your car. You would need the accessory brackets for that engine too.
I have an '81 Fleetwood with an built - up Olds 455 and the stock THM 400 trans. With the tall stock rear end ratio, 2.56:1, its good for 150 mph, no kidding.
4. Install nitrous on your existing engine. So long as its a relatively mild shot, it would work quite well.
Good luck.
