Old 06-22-2004, 01:57 PM
Tony2000's Avatar
Tony2000 Tony2000 is offline
Angry Ignition barrel
I have purchased an 85 Z28 and the barrel and key has been sticking,
the butterfly part has today detached itself and ignition lock is well and truly on hence cannot start or move wheel. Ive looked at the column to see how to remove offending barrel but cannot see anyway of releasing it, the housing is a one piece ally unit with no way of removing.
Ive ordered a shop manual from the states but thats a week away.
Its got tilt column with auto trans.
Can anybody tell me how to remove the barrel without massive hamers and furious anger......?
Regards
Tony
Old 06-22-2004, 02:03 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Ignition barrel
yea you just pull the wheel and everything, and there will be a release bolt you will have to undo and it will slide right out
Old 06-22-2004, 02:15 PM
mike123 mike123 is offline
Re: Ignition barrel
search the forum you'll find stuff on it for sure
i know i had a thread called removing ignition lock or something a while back
Old 06-22-2004, 02:22 PM
Tony2000's Avatar
Talking
Thanks
i did try and pull the wheel yesterday but iys on good & tight will try with puller again
THANKS
Old 06-22-2004, 02:24 PM
Re: Ignition barrel
your welcome, you just have to crank on it and it should pop right off, i used a gear puller to remove mine, removed the bolt and and slid right out
