Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 06-22-2004, 01:47 PM
tokes99's Avatar
tokes99 tokes99 is offline
help installing push button ignition, please!!!
The instruction I got with this push button starter came in chinese--wtf??? Anyway I can not really figure out what wire needs to go where. I really could use some help I do not want to go splicing unnecessarily.
I figure that the red is power, yellow accessory, the black connects to the button which has a black wire that I assume goes to ground, but what does the white wire go to?
Please if you have some suggestions could you help me?
yes, I am a newbie now let the flames begin
Old 06-23-2004, 10:13 AM
tokes99's Avatar
Re: help installing push button ignition, please!!!
c'mon peoples help this brother out!
Old 06-23-2004, 11:12 AM
RSLaser RSLaser is offline
Talk to ashah000 he has that SAME push button, he should be able to tell you...sorry cant be more help.
1991 Plymouth Laser RS
Only sat for a few years....
Old 06-23-2004, 11:46 PM
tokes99's Avatar
ok thanks
Old 06-27-2004, 03:10 PM
zhoos zhoos is offline
scan the instructions and upload the link to it, and us chinese-reading bros will help try to figure out what the instructions are.
Old 06-27-2004, 11:25 PM
Dread209 Dread209 is offline
Send a message via AIM to Dread209 Send a message via Yahoo to Dread209
The system that you have pictured looks to be just a relay and a push button. Your relay should have four terminals that you'll have to use. The terminals should be numbered as 85, 86, 83, 87a and 87.
Don't worry about the fifth one as you won't need it for this application.
85 will be a trigger and 86 will be your ground.
87 will be your out put to your starter wire
83 will be your constant (or battery)
first off you'll need to find out which three wires are your ignition, starter wire and constant. for this you'll need a multimeter or a circuit safe test light. i recommend a multimeter for the safest way to go.
Constant, (or battery) will read 12v all the time no matter if the key is in the ignition or not
your ignition wire will read 12 volts in all but the locked position(that would be constant if it still reads 12v in the off position.)
your start wire will only read 12v when in the start position (go figure)
with you push button mounted where ever you'll need to attach one wire of the button to ignition, and the other to 85 on the relay. 86 will go to ground. 83 off the relay will go to the start wire and 87 will go to constant.
When you press the button you are sending 12 volts to the psitive side of the relay and the relay is in turn sending 12v to the starter. Obviosley you will still need the key in the ignition for this to work, but like the s2000 you won't have to vcrank the motor with the key.
Best of luck and let me know if you have any questions!!!
