Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 01-24-2002, 09:57 PM
"G"-sus!'s Avatar
"G"-sus! "G"-sus! is offline
Send a message via AIM to "G"-sus!
OD Quickie!
Is it safe to switch from Drive to Overdrive (vise-versa)while driving???
Could it cause any problems???
I always get different answers to this question!
Thanks
f-bOmb!:smoker2:
Old 01-25-2002, 12:01 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
I believe the FSM says it's O.K., but you're supposed to let off the gas pedal first. I never did in my first G. Then again, I don't have it anymore so I couldn't tell you of any long term wear. I imagine downshifting from OD to 3 at high speeds can't be very good.
nightmaR3Z
Old 01-25-2002, 07:50 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
I've driven more of my fair share of rental cars and I would treat them like two bit whores. Anyway I used to flick the OD back and forth while driving down the freeway when I was bored. Never seemed to hurt anything...while I was driving them.
Old 01-25-2002, 12:01 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
I think it'd be fine, as long as you're not exceeding the speed of the lower gear, and even if you were, i'm not sure the car would shift, as i'm not sure if it's possible to over-rev an automatic? I used to on my old G20, but not all the time, usually only when going up hills or something like that, where i'd rather be in 3rd than od. also... in traffic where i was in between 3rd and od, i'd just leave od off, so it wouldn't keep shifting...
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 01-25-2002, 12:26 PM
kenchan's Avatar
kenchan kenchan is offline
i do it all the time, with a little blip throttle. i even blip throttle and downshift into 2nd while I brake to take the turns. the best part about this AT is VERY smooth shifting. i even blip it into 1st or even torque brake while I do it to launch into speeding traffic. there was a silver P11 AT on the way to work yesterday that was trying to keep up with my p11...he couldn't because he was letting the AT take care of his shifting. on these p11 AT's you gotta hold the gears (even more so than other AT trannys) because it will quickly try to shift up..and you don't want that when you're trying to fly through some traffic.
no problems when I'm driving it. hehehe. use your tranny to the max, but don't abuse it.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 01-25-2002, 12:37 PM
JustinP10's Avatar
That's weird... with my old P10, it had a switch that would allow you to swtich between shift points, either touring (low shift points), power (higher shift point), or auto. I used to just leave it on power, as it would then shift a little higher, under light throttle conditions. However, even in touring, if i got on it, it'd go all the way to redline. Then again.. my rommates 94 Sentra XE does shift way before redline too, that may be due to his driving style though as before he had the tach he would just let the auto do it's thing, and never thought about it just assuming it went up high in the rpms. After I installed a tach for him, we were both pretty suprised at how long the gears are, and how early it shifts.
Edit: Oh yeah, i forgot to mention... my dad's 91 300zxtt goes all the way to redline when left in drive. maybe even a tad past redline in first and possibly second. I'm not really sure, if i drive that car quickly, i just look at the boost gauge, oil pressure gauge, and the road.
Justin McClanahan
95 G20
Old 01-25-2002, 05:37 PM
"G"-sus!'s Avatar
Smile Thanks!
Nice! Mostly, I drive my baby in OD 'cause it's easier on the engine(and gas milage). It's ALOT more powerful in Drive (obviously), feels good, real good!
When headz try to race me and I'm doin' 55-70 M.P.H, I wanna put it in Drive (turn off OD), but I'm afraid I might damage my tranny, engine, or sumpin' else!
I might do it at a lower speed now, but I'm still "shifty" about it so to say.
Thanks Again!
f-bomb!:smoker2:
Old 01-25-2002, 06:12 PM
nis.k.a.'s Avatar
Well....if it makes you feel better, the FSM says to drive in the city with the OD off and then switch into OD when going on freeways. It does say to let off the gas when switching though. *SHHH* I never did in my old '91.
nightmaR3Z
Old 01-25-2002, 10:01 PM
Koojo's Avatar
Koojo Koojo is offline
Send a message via AIM to Koojo
did you mean you put when you are stopped, you put it in the 1st gear, than once you start to accelerate and hit the redline you move it to the 2nd gear and let it hit the readline again, and change it to D, wait for it to hit the redline, and then push the OD button?
Old 01-26-2002, 02:37 PM
DaPCWiz DaPCWiz is offline
Send a message via ICQ to DaPCWiz Send a message via AIM to DaPCWiz Send a message via Yahoo to DaPCWiz
I shift my tranny while driving all the time
I have alot of fun shifting the AT tranny while driving. But it's usualy only upshifting, not downshifting. I like to launch in first, wait till about 6000 RPM, push it into second, then drive and then od. Seems like the car launches faster. Simply setting the button to power (I have a P10) helps acceleration alot too, but shifting the tranny is more fun
I usually let up on the gas a little or not at all... if I let up on the gas alot while shifting, u really feel the shift, otherwise it's pretty smooth.
I overreved once, I forgot I was in second, and I was flooring it. I think The auto took over and shifted for me, I'm not sure... cuz I felt what seemed like a shift, and I look at the tach, it's at like 7900 RPM and dropping. I promptly poped it into drive, lol.
hp on a P10 peaks at 6000 RPM, right?
Old 01-26-2002, 04:21 PM
kenchan's Avatar
koojo- naw, i let the AT shift up on its own, i just hold the gear in 2nd or 1st while I am going through traffic. the thing is, if you are going any faster than 32mph in 2nd or 3rd, it wont let you down shift to 1st when you punch the gas (my previous altima did)...that's what everyone is complaining about 'slow, sluggish, boggin AT' on this p11.
so you wanna hold 1st gear when you know you will be punching out from traffic. you have to think ahead like you would do in a MT car. so yah, sometimes I go about 40-50yards at about 5500rpms in 1st before I punch out of 1st and into 2nd. but thats the trick with these 'lazy' AT's. you let it ride on 2nd, it wont let you downshift at the critical moment at about 33-34mph even though its not red-line yet in 1st.
infiniti should have geared 1st and 2nd much(!) lower.
Old 01-26-2002, 06:15 PM
nis.k.a.'s Avatar
Come on now, it's a entry-level luxury car that's equipped with an AT. If you wanted a performance AT, something like a '96 Impala is what you look for.
nightmaR3Z
Old 01-27-2002, 01:54 AM
kenchan's Avatar
come on now, they marketed this thing as a high performance touring car that was born in jpn and educated in europe... they shouldve educated this car in jpn...
