Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-22-2004, 07:09 AM
ctaylor2 ctaylor2 is offline
Angry Wheel Bearing
I have a 1995 neon needs some work. I get a grinding noise in the front when driving down the road when I turn to the left it goes away and when turning to the right it gets louder. Can someone tell me which side wheel bearing to replace in this case.
Thanks In Advaned
Old 06-22-2004, 09:55 PM
pegasus757 pegasus757 is offline
Re: Wheel Bearing
go to your local walmart and drive around with your head out of the window along with your girl doing the same .then you should know which side. if its a cluncking noise chances are it the cv joint. do not park ....go fix your car.
Old 06-23-2004, 10:17 AM
Re: Re: Wheel Bearing
Thanks but that will not work. Because we know that a clunking noise is a cv joint and a grinding noise is a wheel bearing but what were asking is that when you load a bearing dose it get quieter or noisier that will tell us what side it is. I believe this would make it the left side even though it sounds like the noise is coming from the right side.
Old 06-23-2004, 11:44 PM
yale329 yale329 is offline
Re: Wheel Bearing
It really does sound like a cv problem, but take you hub caps off the front, after a short drive and a few turns, touch your bearing bolt on each side. Some times when a wheel bearing starts to fail it will be much hotter. Best of luck
Old 06-24-2004, 09:12 AM
Thank for the imput!! The problem is fixed it was the right side wheel bearing that was bad replaced wheel bearing and good as new.
Thanks again
Old 06-24-2004, 05:31 PM
Re: Wheel Bearing
Trust me, the pleasures mine. It sure is nice to be right. Keep in touch if you see my input.I'm always open to advice having a family of nine, plus outlaws expecting me to fix everything. Wayne Canada
