Old 06-21-2004, 11:30 PM
recycle_me's Avatar
recycle_me recycle_me is offline
Send a message via ICQ to recycle_me Send a message via AIM to recycle_me Send a message via MSN to recycle_me Send a message via Yahoo to recycle_me
Question B Seires Swap
im doing a B18 swap in my 89 dx hb. was wondering if i couls swap out hubs with a 90-93 Non ABS hub so i dont have to mod the sv axles to fit my std hubs. if not what should i do. i know i need axles out of a 90-93 teg. but how do i get them to fit in my civic hub.
For You Are Crunchy And Taste Good With Ketchup!
Old 06-22-2004, 12:23 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
you have to get dx or si hubs because the std is 4 speed with teh spline count being less. gott aget 5 speed hubs
you cant get 90-93 teg axles to fit on your std hubs
i think the 90-93 hubs will work but i know defineatly that dx and si hubs work on the 4th gen. but to put 90-93 teg axles into the correct hub, you gotta take the dust shield off the hub, but remember they wont fit in your std hubs
Team Lonely Drivers
Old 06-22-2004, 12:24 AM
i also just noticed you said you have a dx, dx hubs will work. what makes your think you ahve std hubs ? there is a difference between dx and std hubs
Team Lonely Drivers
Old 06-22-2004, 12:30 PM
recycle_me's Avatar
Re: B Seires Swap
i just ment stock hubs sorry bout the std accdently hit the d key. but as for me having a 5 speed i do. so i need to remove the dust plate from the back of my hub and they will slide in spline line up and all that good stuff.
Old 06-22-2004, 01:06 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Re: B Seires Swap
I had to remove the rubber dust ring thing on the axle itself too
