Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-21-2004, 09:58 PM
Luke18 Luke18 is offline
GSR preparation for Turbo
Hello Everyone....
I have a 96 GSR engine in my 97 Civic. I am getting the engine ready for turbo and I wanted to know exactly everything that I would need to change to get the engine and turbo running at max speed.
I was thinking of getting eagle rods, JE 9.0:1 pistons, Shunk2 stage 2 camshafts, Skunk2 valuatrain set and Skunk2 Camgears and anything else that I need to add or I missed. Thanks for the help and advise.
Old 06-22-2004, 05:32 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: GSR preparation for Turbo
from what i've heard you will NOT want to go skunk2 cams... way way way too much overlap... go for some turbo cams... can't remember who makes em, it's 3.30 in the mornin and i'm not thinkin straight
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-22-2004, 06:39 AM
YellowITR479 YellowITR479 is offline
crower got some nice "turbo" cams. you dont want something too radical on your car. You definately missed a fuel system up above, you will also need some kind of a piggy back ecu or an rising rate pressure riser, injectors, pump. Look around on E-Bay for ECU's, I got a good deal on my Hondata from there for only like $150.00 more than an VAFC. Your gonna need an exhaust and gagues (good gagues arent cheap). Eagle rods and JE pistons are a great combo....stick with them. You should send your block out and have it sleeved for turbo use to ensure that you havent wasted your $$ on pistons and rods just to destroy them. Your stock clutch will not last very long so that will die soon after you add boost unless you drive like a granny.
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-23-2004, 01:40 PM
I decided to go with the Crower Stage II turbo cams. Also I wanted to know which cat back to go with the Tusdo Fireball or the Skunks2 system. Will the DC 4-1 header work well the one of those two cat backs?
Old 06-23-2004, 03:47 PM
Tusdo Fireball....wtf is that....if you are going turboyou will need a 3" exhaust unless u wanna choak on the top end......im guessing you dont know too much about turbos cause you dont use a header on a turbo car...you use a turbo manifold. I think before you go and spend your money, go invest in a couple books mainly "turbocharging" and basic engine knowledge type of book to give you some head up about engines.
Old 06-23-2004, 03:50 PM
Sorry guys......by the way, I have my kit up for sale if you are interested
Turbo,Manifold,40mm wastegate,Frontmount w/ plumbing,Injectors,Downpipe,GReddy Boost Cont,Apexi S-AFC,GReddy BOV....$2500.00 or bo
