Old 06-21-2004, 07:56 PM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
Radiator Leak?
I'm looking at getting an 94 integra today w/ a B18b motor. After driving it for about 15-20 min, I popped the hood and there was small amount of sweet smelling steam coming from the radiator. I then rubbed my finger along the top and found a small amount of coolant on the top of the radiator by the hand latch. It was almost like it was sweating. The car had been stored in the winter and not driven much lately. Does anyone know what the problem could be or if they have had the problem before? How hard is it to fix?
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 06-21-2004, 10:34 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
I would say that the only real, long-term solution is to replace the radiator.
Old 06-21-2004, 11:20 PM
Re: Radiator Leak?
How expensive and dificult would that be? I was thinking of getting a performance one then. Also, what if the person just overfilled the coolant mixture too much?
FOR SALE
Old 06-22-2004, 12:14 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
if it was filled too much then it comes out of the reseivor. if it leaking by hood latch, which is memeory serves correctly its by the radiator cap then check the radiator cap. if it is not near the radiator cap then you might have a crack or hole in your radiator, which would then i would recommend replacing. but if hte radiator is the only thing then its not that bad
Team Lonely Drivers
Old 06-22-2004, 12:45 AM
Re: Radiator Leak?
Im gonna go check it out tomorrow or thursday. Ill look closer then
FOR SALE
Old 06-22-2004, 05:37 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Radiator Leak?
my friend had a cracked radiator hose on his 98 prelude.. took it into the mechanic and they had to replace the whole radiator.. cost him like 450.. radiators can be expensive..
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-22-2004, 01:00 PM
As with most things, you can save alot of money if you do it yourself. Not to mention that anti-freeze is toxic, and you pay to dispose of it properly at a shop. I'm not sure what is invloved to get your radiator out, but I doubt that it would take any longer than an hour or two. And as I found out, sometimes the better aftermarket radiators can be cheaper than a auto-zone replacement radiator, so look around.
Old 06-22-2004, 02:13 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
yeah, if you can go to a junkyard shop, they can get you an aftermarket fully aluminum one for under $100, then the rest is installing it yourself. It shouldn't take more than 1 hour.
Old 07-02-2004, 11:47 PM
Re: Radiator Leak?
Well i bought the car and the steam doesn't appear anymore but there is coolant on the top of the radiator and smells sometimes, like its burning
FOR SALE
Old 07-04-2004, 09:00 AM
tsugsr tsugsr is offline
Re: Radiator Leak?
how many miles are on the car?? most Integra's around that year, including my 95 are prone for the plastic top to seperate from the aluminum bottom to crack and spill coolant out. at or around 80K +/- 15K miles, its a very common problem and a screw up on acura's part. mine happend just about 4 miles ago at 82K. but anyways, to fix it, take it to a dealer and spend the 450+ to fix it, or buy a new OEM replacement at www.radiatorbarn.com for about 110, and go to www.team-integra.net, look under the artical section and maintance, and look for an artical on radiator replacement for a G3 integra, shouldnt take more than a few hours. and unless your car is highly modifyed. IE lots of boost or a big shot of Nitrous, there is absolutly no need for an aftermarket radiator, the weight savings are minimal and the OEM one will work just fine even with basic bolt ons.
