Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 06-21-2004, 08:31 PM
solotop186 solotop186 is offline
sr20vet?
what if i were to take a sr20ve and put the sr20det header/ turbo and buy a front mount intercooler kit
would that make a better engine than a sr20det or would it for some reason be bad
Old 06-21-2004, 09:53 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: sr20vet?
The compression ratio is too high in the SR20VE to do that safely. If you want turbo, get a DET. If you want N/A, get a VE. If you REALLY wanted to boost the VE, just be careful doing so. And remember that your transmission will need some work to handle the extra power.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 08-02-2005, 10:56 PM
beige01pathfinder beige01pathfinder is offline
Send a message via AIM to beige01pathfinder
cant u buy a det motor and a vvl head? that would be the best bet since the compression ratio would be of a sr20de and the head off of a sr20ve. the buy one of those vetch silonoid switch and set it to kick in when u want..right?
Old 08-03-2005, 06:55 PM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: sr20vet?
missing the point here guys, the head of a ve will have different compression charecteristics than that of a det head, combustion chamber is different size, you could always go low comp pistons but thats another thing on your list
Old 08-03-2005, 09:59 PM
fugiot's Avatar
Re: sr20vet?
Actually, that's not the problem when you swap the VE head. It's just a slightly different design and there is some drilling for oil feed lines required and some other stuff. Not really sure. You'd be better off getting a VE and turboing it after you put DE or DET pistons in it. But like I said, there's really no point unless you're looking for a turbo SR20 with more hp than torque. You can get the same results with a DET with JWT S3 cams which will give you turbo power and a peaky top-end.
Don't make me ANGRY
Old 08-04-2005, 09:33 PM
95VER 95VER is offline
Re: Re: sr20vet?
There is a guy(Big Jon) on the sr20forum who did this and because the VE head is so much more effcient he was getting 238.8hp to the wheels with 7 psi. He is still running 11.8:1 compression ratio, and it's off a T25.
