Old 06-21-2004, 07:29 PM
redrider4192000 redrider4192000 is offline
hey...cv axle trouble..?????
hey..i just bought a 92 civc si and i need to change the drivers side cv axle....i have never done this before and could use a lil help......where do i start??is it hard to change..??HELP plz.....!
Old 06-21-2004, 08:34 PM
jameskersten jameskersten is offline
Re: hey...cv axle trouble..?????
not too hard. jack it up. remove wheel. remove nut 17mm on lower side of ball joint (dont forget kotterpin), bang the ball joint loose, remove nut on end of hub assm (33mm i believe) that hold the axle in place, now pop out the axle from hub. sometimes its needed to banged it out. stick a pry par in between axles and trans and pop out axle. just pull it out from there. install is the oposite. push axle into trans until you here and feel a pop.
1993 honda civic si -turbo charged b18c1
dynoed: 316whp at 11lbs
