Old 06-21-2004, 05:49 PM
firetecs firetecs is offline
Send a message via MSN to firetecs
Question programming ford remotes f-150
Hello, how can I programming an aditional remote to my truck?
Actually, I have one remote programmed, but i has an another one remote of the other same model truck, I'm looking to programm this control to my truck, because I need two remotes, but I don't know programming. TNX.
Old 06-25-2004, 08:51 PM
rlburdet rlburdet is offline
Re: programming ford remotes f-150
To program the transmitters yourself:
Place a key in the ignition and turn from 2(lock) to 3(off)
Turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position.
The doors will lock/unlock to confirm that programming mode has been entered.
Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
When you have completed programming the remote transmitters, turn th ignition to 3(Off) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
Old 06-26-2004, 12:19 PM
landyacht's Avatar
landyacht landyacht is offline
You beat me too it!
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 08-09-2004, 01:30 AM
Willie0508 Willie0508 is offline
dunno what year model it is but in my 2000 F-350 It only took 3 times off t on i dunno why but i had a friend with the same Truck that it too all 8 mabe that helps
