Old 06-21-2004, 06:29 PM
sLADe781 sLADe781 is offline
Lug nut key
So recently I realized that the lug nut key for my tires are missing. I contacted the guy I bought the car from and he said that he doesn't have it either. Is there any way that I can get a replacement key? Or am I super screwed???
Old 06-22-2004, 12:30 AM
Hotshot8792 Hotshot8792 is offline
the mitsubishi dealership has a master key and can undo them, just get them to undo them real fast and just drive home on 4 lugs, i've done it before, its fine. My mitsu dealership did it for free, but then again, we have the best service department in the state, and my uncle is the director of used acquisition there.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-22-2004, 12:56 AM
azn3000GTRacer azn3000GTRacer is offline
Re: Lug nut key
all the lock nuts are the same..i think..... I compared it to my friends SL mine worked on his and his worked on mine so if u know somebody else with a 3000GT i might work.
Old 06-22-2004, 01:37 AM
Re: Lug nut key
Hotshot8792, if they didn't do it for free, do you know how much it would cost?
azn3000GTRacer, do you know if a base model's key would be the same or does it have to be type for type (base for base, SL for SL, etc). Also, does it have to be the same year or any year would work!?!
Thanks guys!
Old 06-22-2004, 01:38 AM
Re: Lug nut key
na my friend has a 94 SL and i have a 96 VR4 and his lug nut works on mine just fine
Old 06-22-2004, 10:03 AM
Igovert500's Avatar
blue + red light magnet
Re: Lug nut key
Just don't drive too long with only 4 lugnuts, or your rotors will suffer.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-22-2004, 10:17 AM
if they dont do it for free, which they should, it shouldnt cost you anymore than a couple of bucks because it only takes them about 30 seconds to undo all four of them. Just go up to them and tell them that you lost your locking key and needed to just get the four locking lugnuts off. Yea, dont drive on 4 lug nuts for a long time, but they'll be good enough to drive back home.
Old 06-22-2004, 03:03 PM
John Pannebaker John Pannebaker is offline
Re: Lug nut key
I replaced all my keyed lug nuts with standard lugs because I got stranded once when the key was stripped. I was driving at 85 mph when the right front tire went flat hardly felt a thing just a slight pull to the right. When I got out to see what was wrong, only to find the tire was in schreads. My dog and I had to hitch into town and call a flat bed tow truck (all wheel drive) all to change a tire. The only good thing to come of this is I now have great respect for low profile tires for there safety value. If they had been high profile i would have surely lost control and ended up in the ditch or worse.
Old 06-22-2004, 04:29 PM
Neoscarecrue Neoscarecrue is offline
Re: Lug nut key
i had a lug tool,but it didn't fit.i just filed down one side and it worked.
Old 06-22-2004, 06:31 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I had two VR4s at the same time and the keys were not interchangable. The lug can be removed, but it usually ruins the locking piece.
Resistance Is Futile (If < 1ohm)
Old 06-23-2004, 12:42 AM
Re: Lug nut key
really??? that's wierd my friends SL lock nut works on mine just fine
Old 06-24-2004, 11:26 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Heh there are probably only a few different ones and you got lucky with your friends key. Is wheel theft realy that big a concern that you need a locking system like this?
Old 06-25-2004, 01:26 AM
Re: Lug nut key
The locking system came with car when the first owner bought it (I'm only the second owner). And since he doesn't have the key, I have to buy a new one.
Old 06-27-2004, 04:11 AM
osok_deadeye_21 osok_deadeye_21 is offline
I lost my lug key and had the mitsubishi dealership break them off I just bought new rims anyways.
Old 06-27-2004, 04:06 PM
Re: Lug nut key
osok_deadeye_21, how much did they charge you when they broke off the locks? How come they didn't just take 'em off? Wish I had money to get new rims like that... :oP
