Old 06-21-2004, 05:06 PM
Bigceeloc's Avatar
Bigceeloc Bigceeloc is offline
Send a message via AIM to Bigceeloc Send a message via MSN to Bigceeloc Send a message via Yahoo to Bigceeloc
What is ETS? Ihad to ask
Sorry for the noobish post, but I really don't know what it is or does.
Old 06-21-2004, 09:49 PM
The Right Formula's Avatar
The Right Formula The Right Formula is offline
Send a message via AIM to The Right Formula
Re: What is ETS? Ihad to ask
ETS stands for "Enhanced Traction System". Basically, it helps to prevent wheel spin (thus helping to prevent loss of traction). Nifty little feature to have, and I loved it at first, but after comparing the two systems (one on my GA, the other on the Formula) I can say that the GA is there for looks. Sure it tells you when you're spinning or the wheels are at thir limit, but other than that, it's useless. Makes burnouts trickier to handle also. Unless it's raining or snowing out, I just leave mine off.
Do a search on Yahoo for 'grand am ets' if you need more info.
--Jason
2002 Light Pewter Metallic Formula A4:
Cold Air Intake with sealed MTI Airlid, ported and polished TB, smooth bellows
Old 06-28-2004, 09:46 PM
Pvt_Murphy Pvt_Murphy is offline
the ets is really pretty much worthless on the GA
funny thing:
doing this:
http://non-standard.dhs.org:83/events/Grand%20AM%20GT1/
in the rain doesnt set it off
but taking off just a whee bit too fast on a light on dry pavement does.
It did go off like 3 times at an appropriate time, all on rainy days, but it was un called for; really wish it was off by default.
Old 06-29-2004, 07:27 AM
achievasc92 achievasc92 is offline
the ETS just applied to the brake to the slipping wheel and/or retards timing intil the slippage stops, its a pretty archaeic system, but I guess it works well enough
Old 06-29-2004, 09:32 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
No no no no , you guys must be from america or some place where the ets isnt needed cus you need the facts , when the ets senses wheel spin all it does is cut out gas (power) not apply a brake nothing to do with no limited slip or nothin like that it is much simpler than you think. I drive on ice with that thing on and my car will not move at all unless i let off the gas and take it easy. You cant lay a patch with the ets on either cuts out to quick , it works like the rev limiters.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 06-29-2004, 09:33 AM
Ask flatrater , hes a gm mechanic he could explain it better than me.
Old 06-29-2004, 08:28 PM
copied from the GM website
"enhanced traction control monitors the rotation of the front wheels during acceleration. When the system detects wheel spin in a particular wheel due to a slick driving surface, it applies the brakes to that specific wheel until traction is regained. Standard on Regal GS, full-range traction control helps sense drive-wheel slippage at any speed and reacts by automatically modulating the brakes and reducing engine torque until the driver regains control. This maximizes traction on slippery surfaces such as loose gravel, snow or ice."
applies the brake and lowers torque by spark retarding.
Old 06-30-2004, 07:16 AM
GASE 95 GASE 95 is offline
ok so it does both...
Old 07-01-2004, 10:26 AM
Bigceeloc's Avatar
Ooo, good to know, I drive on gravel on occasion. Thanks for all the replies guys.
