Old 06-21-2004, 04:44 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Check engine light ?!?!
My car seemed to be running fine until i was rolling at about 20 miles an hour... wanted to play around a little bit and threw it into first. First gear doesn't red line until about 30-35 miles per hour so I did not think it would be a big deal.
The second my car jumped the check engine light turned on. Now first gear seems to lag in the middle of the gear. Maybe this is what "bogging" is I am not quite sure. But I just got the car so I am concerned something might be wrong with it. The bogging isn't too severe and doesn't always happen. But it never happend before this.
If anyone can help me out that would be great. Maybe fill me in on how to check what could be turning the light on.
Thank you!
Travis
Old 06-21-2004, 04:56 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Re: Check engine light ?!?!
pull the code. Pull back on the carpet on your passangers floor and look for the eye on the ecu. Turn the key to on and count the long and short blinks.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 06-21-2004, 06:50 PM
Onimacus's Avatar
the ECU blinks 9 times.
Travis
Old 06-21-2004, 06:55 PM
Hybrid1990crx's Avatar
Code 9 is #1 cylinder position. Looks like you may have slipped a tooth on your timing or something. Who the their right mind drops into 1st gear at 20mph?!?!?
Old 06-21-2004, 06:59 PM
Onimacus's Avatar
Obviously I am not in my right mind heh.... So what does all this mean for me? This is my first Honda and I don't know very much about what kind of work needs to be done for this problem.
Travis
Old 06-21-2004, 07:06 PM
I'm not totally sure how to go about trouble shooting it. But if it is timing, is sounds like it slipped down low and not up at the cam gear.
Old 06-21-2004, 07:07 PM
Onimacus's Avatar
Sometimes it doesn't red line at the same spot as it used to... it used to red line at 7400 but sometimes i will hit the rev limiter at like 6800.... I don't know if this has anything to do with it.
Travis
Old 06-22-2004, 10:03 AM
b16 crx kid's Avatar
b16 crx kid b16 crx kid is offline
yeah if its not good and warmed up it does that, i have tried to like drive off from somewhere flooring it, trying to show off hehe, and it just hit the rev limiter and i felt dumb.
1988 Honda CRX SI -JDM B16A, Y1 tranny, Black Rota Slipstreams(15's) w/ Falken Azenis Sports, 99-00 Civic Si cold air intake, Type R cams, valve springs, and retainers. battery in da back, B&M short shifter, DC sport 4-1 ceramic headers, no cat, Custom mandrel bent 2-1/4 exhaust w/ resonator and "RS type" muffler. One day i will have JRSC
Old 06-22-2004, 11:05 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
could be one of two things:
1. Your timing slipped a tooth or two off.
2. If ur car was a dx, and it was wired for an si (mpfi) the wires added at the dist. could have come loose (if they weren't soldered)
If you have an si, then I'm almost 100% sure ur timing has slipped.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-23-2004, 01:26 PM
Onimacus's Avatar
Its a DX model.... and i talked to my friend that works at a honda shop in vegas, and he said to buy a new distributor. So as soon as I can I am going to hit the junk yard.
Also... My ECU is constantly blinking while I am driving... is that a bad sign?
Travis
Old 06-23-2004, 02:00 PM
your ecu is blinking because its throwing a code. so until you get it to stop throwing a code its going to continue to blink.
Old 07-02-2004, 02:02 AM
mattio781 mattio781 is offline
Send a message via AIM to mattio781 Send a message via MSN to mattio781 Send a message via Yahoo to mattio781
i got the same problem except i didnt drop into 1st doing 20 recently, but my engine light comes on for no reason, driving granny style, sometimes it takes as little as 10 minutes to come on, or sometimes it just dont come on at all, but yeah i tried looking at my ecu but it is just blinking normaly, do i have to turn of the car then turn the key on to check for the code?
Old 07-02-2004, 02:03 AM
oh yeah its a 91 si with a header and blown gasket off the header itself, maybe thats the reason
Old 07-02-2004, 07:17 AM
travagliante's Avatar
travagliante travagliante is offline
As long as the car is on it will flash the code. And know a exhaust problem has nothing to do with the timing.
Old 07-02-2004, 07:34 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
My ECU is blinking like that one stops one stops one stops... figure code 1=oxygen content... going to replace O2 sensor whenever I get a chance to use a garage.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
