| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Idle prob
I just adjusted my valve clearance and now my idle is around 200-300 and it stutters when cold. But when it get really warmed up it goes back to 700. Any ideas? Car works great after the valve adjustment in terms of pickup and performance, except for the idling.
Uniquely Stock !! |
Re: Idle prob
o/k.let me guess.1.4-no?1.5?6-8-2.0, diesel?--coupe--aerodeck?year about 91 --2004.?
Re: Idle prob
sorry, my car is a 97 Honda Civic EX VTEC Coupe.
Uniquely Stock !! |
Re: Idle prob
replying from uk.what engine size?just to narrow it down.have you got an engine code?could be d16** or others.
Re: Idle prob
its a 1.6 D16Y8 i believe. SOHC VTEC.
Uniquely Stock !! |
Re: Idle prob
check the idle air control valve
FRIENDS DON'T LET FRIENDS DRIVE STOCK |
Re: Idle prob
idling at 200-300 RPMs is i think impossible. But yea check the idle air control valve. Adjust it and see if it makes a difference.
Re: Idle prob
Yeh its possible cuz its just above "0" and it cut off once at a stoplight. once it gets really hot, it goes back to normal about 700. where is the idle air control valve?
Uniquely Stock !! |
Re: Idle prob
coming back to what you did first,valve clearances should be (cold)0.18to 0.22 inlet--0.23 to 0.27 exhaust.also check air/vac pipes for integrity.plug gaps1.0mm to 1.1mm
Re: Idle prob
i adjusted the valves to spec and also gapped the plugs.
Uniquely Stock !! |
I got a 94 Integra with the stock engine and its doing the same thing, is there a temporary solution or is it just that old
The engines a B18b
Re: Idle prob
IAC valve is right behing the intake manifold/ two bolts that hold it and 2 coolant hoses.
Re: Idle prob
typo
Re: Idle prob
Well for my 91 CRX Si D16A6 motor. I had to unplug the IACV (Idle Air Control Valve) while the car was running and the adjust the Idle Screw which was located on the Throttle Body.
