Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-21-2004, 02:22 PM
bad30th bad30th is offline
EVAP system help needed!
Sorry this is lengthy, but here goes...
Car is a 97 Z28, 6 speed, 51000 miles, no real engine mods....
I had been getting code p1441 (EVAP System Flow During Non-Purge), so someone recommended I checked for vacuum at idle in Part 7 in this diagram, found that there was, so I replaced the part. Problem seemed to be solved.
Couple days later, another code. This time p0441. I know this is EVAP System No Flow During Purge. Did a search, and found that maybe my lines are clogged/leaking/etc. Pulled the rear wheel and checked all the EVAP lines in the fenderwell going to and from the Charcoal Canister. I blew into them, and there doesnt seem to be any clogs. All the lines look fine, as well as the canister itself.
So after figuring out that everything at least appears to be working properly, I am still getting code P0441 (no flow during purge). So I am thinking there HAS to be a clogged line or part. Since it was only $15, I replaced Part 11 in this diagram.
When I pulled the old one off, I noticed little black pieces falling out of it. Tapping on its side, more black pieces. I am sure these are little pieces from the charcoal canister.
So I replace the part with the new one, reset my SES light, and think I have solved the problem. About 2 days later, same light. Pulled off NEW part 11, tapped, and whadda-ya-know....little black pieces. Note that these pieces did not fall out of the new Part 11 before I used it.....
So now the only thing left to replace is the Charcoal canister, which I did. While I had it off, I blew into the line that runs from the canister to the engine bay, and a friend verified that there was air coming out when I blew. No clog there. Threw everything back together, reset my light. I pulled Part 11 off again and tried to tap out as many of the little black pieces as I could, and reinstalled.
So now I have a new Canister, new Part 7 and Part 11. I also replaced my gas cap with a new one, just in case. Day later, same code, p0441.
There arent any parts in the system left to replace, so the only things I can think of is either...
a) the old Canister permanently clogged my new Part 11, so I am going to pick up another one today (only $15)
b) there is a clog in a line between Part 7 and the Throttle Body, or between the Canister and the Fual tank somehow...
If ANYONE has any ideas, I could really use the help! I am pulling my hair out trying to fix this thing, and I know that if I take it in to the dealer/mechanic, they are just going to want to replace all the parts I already did, and then rape me on the bill......grrrrrrr
Anyway, all help is appreciated.
Thanks!
Old 06-21-2004, 08:09 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: EVAP system help needed!
take it to the dealership and have it smoke tested for a leak. unless you happen to have a nitrogen smoke machine at home.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-23-2005, 10:12 PM
coolcar coolcar is offline
Is the Emissions Canister located back under the rear wheel
Old 07-23-2005, 10:20 PM
89IROC&RS's Avatar
again, old old thread, we try not to revive old threads like this.
Old 07-23-2005, 10:39 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
Re: Re: EVAP system help needed!
see this is why i dont search for to much on this thread, as you read old stuff you wont notice how old it is and you end up with a question and then the next thing you know the reply box is right there so you type a reply and accidenly bring back and old thread...
this dude didnt want to make a new post if he could find his answer but he ended up bring back an old thread.
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 07-23-2005, 10:42 PM
89IROC&RS's Avatar
meh, details, what ya gonna do.
Closed Thread
