Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-21-2004, 01:53 PM
nzalmasri nzalmasri is offline
Service Engine Light
The service engine light on my 2001 Maxima came on. The code is P0420 and it reads Catalyst efficiency below threshold, bank 1. One mechanic said it is the spark plug number 1. Other mechanic said it is the Catalytic Converter. The differance is over $200. Anyone can help? Thanks.
Old 06-21-2004, 04:38 PM
vinceleto vinceleto is offline
Re: Service Engine Light
I have the same problem same code on my 2000. It comes on and off every once in a while. My gas milage is still good. I have about 60k miles and I'm thinking about chaging the plugs.
Old 06-21-2004, 04:59 PM
I changed the plugs because they are the cheapest and reset the light. I doubt if they were the real cause. The old plugs look in good condition.
Old 06-24-2004, 03:18 PM
The light came on again. Anyone knows what is bank 1 and where it is located? Thanks
Old 06-30-2004, 01:02 PM
habenero2002 habenero2002 is offline
Send a message via Yahoo to habenero2002
2000-2001 maxima need to have their computer reprogrammed by the dealer to fix this problem. Bank one is the cylinder head closest to the firewall
Old 07-02-2004, 11:02 AM
Don't they charge arm and leg for that?
Old 12-06-2006, 05:02 PM
gentle_big_man_4_u gentle_big_man_4_u is offline
The answer to your ? is looking at the engine with the fanbelt right in front of you bank one is the left side of the motor.
Old 12-06-2006, 05:17 PM
Does anyone know why my 2001 Maxima can not be emmision tested? the tester said the cat was not ready, and my scan tool says the same thing?
Old 12-18-2006, 08:44 AM
Mrbizness1 Mrbizness1 is offline
If the check engine light was reset recently and the vehcle hasn't been driven enough (ususlly around 25+ miles) you will get the not ready indication.
Someone told me it was to prevent people from clearing the light and going to get it inspected before the code resets the light.
Old 12-18-2006, 08:47 AM
If the check engine light was reset recently and the vehicle hasn't been driven enough (usually around 25+ miles) you will get the not ready indication.
Old 12-18-2006, 10:20 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Originally Posted by Mrbizness1
...to prevent people from clearing the light and going to get it inspected before the code resets the light.
Reset clears all ECU registers which contain data to adjust for sensor characteristics. Each sensor is individual eg slightly different from others and they do age differently... Thus there must be a 'learning' period where ECU adjusts for best performance and corrective data is entered in to adjust for any biased sensor(s). The 'learning curve' contains certain speeds, rpm, temp etc requirements during various drive cycle times - check what and how via top left 'Favorite Links' -at link below.
Its not '25miles' but the factory specified different drivin conditions fulfilled to collect the data (which may become at 25miles). Check out, theres a chart howto drive this 'break in' for example after MAF cleanup/replacement. If one bypasses this teach process, the only problem possibly is longer time to get this finetuning through.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 12-23-2006, 07:27 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Ok Here is the answer to all your questions. First off , Mileage is important to know on your Maxima. If your mileage is with in 8 years or 80 Thousand Miles , a Cat Converter would be covered underwarrenty. But First the Nissan Dealer Would Probable Need to do a ECM ( Engine Control Module) Reprogram with updated Software. After the Ecm reprogram you will need to probably drive the car for at least 100 miles or so . After wards , have them Recheck your SRT's ( System Readiness Tests) To see if it complete. When Codes are erased or ecm are reprogrammed , all SRT's are cleared and the systems have to run self checks to complete. If a System can not be completed the it is safe to say there is a problem in that system . So your P0420 B1. Bank 1 The location is the side of the Engine back by the fire wall . The ECM reprogram should be covered under warranty with the 8/80 i describe in the beginning. Emissions warranty . If they say it's not. Challenge them on it, that is if your in warranty. Under 80k miles. If you have any more Questions on this , Feel Free to ask .. GL ..
Old 01-01-2007, 03:23 PM
Chester86 Chester86 is offline
opcorn: Howdy folks,
Looks like its time for me to join the club also. I recently got hit with the P0430 code also. IT says its the second Cat in Bank 2. Should I just go ahead and change it out and see from there?? I will reset the ECU tonight and will check the plugs and basic diagnostics on the car later today . . just to ensure everything is OK first . . but, based on the respones I have seen . . Cat Bank 2 replacement should do the trick. Let me know what you guys think. Thanks!! Happy New YEar!!
--Chester86
