Old 06-21-2004, 12:50 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Interference Engines?
Which engines are interference engines? Is there a site to go to? I have the '99 2.0L SPI. Thanks!
Old 06-21-2004, 05:47 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Interference Engines?
Your 99 is definitely an interference engine. Had my 99 2.0L to Ford when the fuel pump went out and the service guy advised me to change the timing belt every 60k miles as this is an interference engine.
Old 06-21-2004, 08:09 PM
nditech nditech is offline
what is an interference engine? I understand that my 1.9L is also an interference engine, but what does that mean?
Old 06-21-2004, 09:58 PM
Jet-Lee's Avatar
Banned
If you blow the timing belt, your pistons will hit your valves and damage them and possibly your piston(s).
Old 06-22-2004, 05:39 AM
Pontiac Guy
To expand on Jet-Lee's explaination, an interference engine is an engine where the valves are timed so that they open and close in sync. with the pistons. The clearances are so tight that if the timing belt breaks the valves stop immediately but the pistons continue to move up and down. When this happens the pistons will strike the open valves bending them.
Old 06-22-2004, 07:39 AM
Jet-Lee's Avatar
Banned
Thanx GTP
Old 06-22-2004, 04:07 PM
thanks for the insite i guess i better make sure the timing is tdc when i put it back together then. since i am replacing the timing belt and water pump shouldnt be to hard to put it tdc.
Old 06-22-2004, 09:21 PM
I think I have found out what it looks like it the timing is off. here is a link to the pics that i took. Not to sure how to post them here so i had to add them to the f-150 site i use also.
http://www.f150online.com/galleries/...w.cfm?num=6104
let me know what you guys think I think i am just going to get a new engine.
Well I brought the head to NAPA and they said it was a broke seat. I had the do all the head work and replace all seats. Only had two valves bent. will pick the head up tomorrow.
Old 10-06-2004, 11:27 AM
towser42 towser42 is offline
I have a '93 (1.9L engine) with 90,000 miles on it. I'm a little ticked off because the timing belt just went and I was told by my brother-in-law, when he gave me the car, that the timing belt had been changed already (he is "no longer with us" so I can't even question him on it).
I plan to tackle the belt/waterpump myself (can't afford anything else), however, if there are bent valves, I'll probably have to junk the car. Is there anyway for me to tell if the engine has been damaged before I try to tackle the belt?
Thanks,
Old 10-06-2004, 04:22 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Escorts are not supose to be interference, I have fixed a few escort's that had the timing belts break, and the valves where fine, just slaped on a new belt and they where on there way.
But I have heard of it happening, I guess if every thing is just right, the valve and piston will kiss.
I make slow Escorts less-slow.
My cardomain
